error after sql patched update for v2.0
  • beeloo
    • Nov 2010
    • 62
    After I ran the mysql patch update, I checked the zabbix_server.log and I noticed below error:
    1287:20120607:092135.738 Database is down. Reconnecting in 10 seconds.
    1287:20120607:092145.739 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'root'@'localhost' (using password: NO)
    1287:20120607:092145.739 Database is down. Reconnecting in 10 seconds.
    I remembered when I configure the database "zabbix", I was using the username zabbix to connect, not sure why now it said it try to using "root" @ "localhost"
    Could someone please tell me how to fix it?
    Thank you.
  • beeloo
    • Nov 2010
    • 62
    After I reinstalled v1.8.13 and reverted the database, it works. Then, I upgrade to v2.0 and upgrade the mysql patch, i have the same error again:
    Please advise.
    • beeloo
      • Nov 2010
      • 62
      Still have no luck to figure this out. Could someone please point me to right direction?
      • beeloo
        • Nov 2010
        • 62
        Someone please help..
        19973:20120716:091231.954 Starting Zabbix Server. Zabbix 2.0.1 (revision 28455).
        19973:20120716:091231.954 ****** Enabled features ******
        19973:20120716:091231.954 SNMP monitoring: YES
        19973:20120716:091231.954 IPMI monitoring: YES
        19973:20120716:091231.954 WEB monitoring: YES
        19973:20120716:091231.954 Jabber notifications: NO
        19973:20120716:091231.954 Ez Texting notifications: YES
        19973:20120716:091231.960 ODBC: NO
        19973:20120716:091231.960 SSH2 support: NO
        19973:20120716:091231.960 IPv6 support: NO
        19973:20120716:091231.960 ******************************
        19973:20120716:091231.971 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'root'@'localhost' (using password: NO)
        • dougbee
          • Apr 2011
          • 68
          That error looks like you're trying to connect as root without a password. What does your zabbix_server.conf indicate for a database username and password?
          Did you compile Zabbix from source or install binaries? Note the new location of the config file, unless you specified otherwise:
          http://www.zabbix.com/documentation/.../upgrade_notes
          • beeloo
            • Nov 2010
            • 62
            Hi dougbee,
            Thanks for your reply. In the zabbix_server.conf, I'm using the following setting:
            DBName=zabbix
            DBUser=zabbix
            DBPassword=xxxxx
            So I assume it should be using zabbix@localhost instead, right?
            I complied from source. I looked at the https://www.zabbix.com/documentation.../upgrade_notes before but still couldn't figure out why.
            Please advise.
            Ricky
            • beeloo
              • Nov 2010
              • 62
              The strange thing is, I was able to use to the same exact zabbix_server.conf to a server running the 1.8.14 version and it is running fine.
              I just have a problem when upgrade it to a test machine to version 2.0.1 and it gives me this error.
              • dougbee
                • Apr 2011
                • 68
                If you compiled and *did not* specify something like "--sysconfdir=/etc/zabbix" then odds are zabbix is now looking in /usr/local/etc:
                1.5 Changed default configuration directories
                configuration files location
                /etc/zabbix → /usr/local/etc (depends on compile-time installation variable sysconfdir)
                Where is your current zabbix_server.conf with the proper credentials?
                • beeloo
                  • Nov 2010
                  • 62
                  Oh, I was just copied the /etc/zabbix/zabbix_server.conf from the server running 1.8.14 to test server running 2.0.1. Is that a problem?
                  • dougbee
                    • Apr 2011
                    • 68
                    That depends; if you did not specify "--sysconfdir=/etc/zabbix" when you compiled the 2.0.1 server, you may need to copy the file to /usr/local/etc/zabbix_server.conf ..
                    • beeloo
                      • Nov 2010
                      • 62
                      Could you please where can I find the zabbix_server.conf from the source? It used to be at /zabbix-x.x.x/misc/conf/, but no longer there under /zabbix-2.0.1/misc/, I couldn't find the conf directory.
                      • beeloo
                        • Nov 2010
                        • 62
                        I see. When I complied, I used below syntax:
                        ./configure -enable-server -prefix=/usr/local/zabbix -with-mysql -with-net-snmp -with-libcurl -with-openipmi
                        So I should copy the zabbix_server.conf to /usr/local/zabbix instead of /usr/local/etc?
                        • dougbee
                          • Apr 2011
                          • 68
                          I *think* prefix only specifies where the binaries go. The config would still be under:
                          • beeloo
                            • Nov 2010
                            • 62
                            I just copied zabbix_server.conf to /usr/local/zabbix and /usr/local/etc/ but when I start the zabbix server, same result, I see the same error message....
                            • beeloo
                              • Nov 2010
                              • 62
                              #15
                              [root@zabbix3 etc]# pwd
                              /usr/local/etc
                              [root@zabbix3 etc]# ls
                              zabbix_server.conf
                              [root@zabbix3 etc]# /etc/init.d/zabbix_server start
                              /etc/init.d/zabbix_server start: zabbix_server started
                              15756:20120717:112900.096 Starting Zabbix Server. Zabbix 2.0.1 (revision 28455).
                              15756:20120717:112900.097 ****** Enabled features ******
                              15756:20120717:112900.097 SNMP monitoring: YES
                              15756:20120717:112900.097 IPMI monitoring: YES
                              15756:20120717:112900.097 WEB monitoring: YES
                              15756:20120717:112900.097 Jabber notifications: NO
                              15756:20120717:112900.097 Ez Texting notifications: YES
                              15756:20120717:112900.097 ODBC: NO
                              15756:20120717:112900.097 SSH2 support: NO
                              15756:20120717:112900.097 IPv6 support: NO
                              15756:20120717:112900.097 ******************************
                              15756:20120717:112900.101 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'root'@'localhost' (using password: NO)
                              15756:20120717:112900.101 Database is down. Reconnecting in 10 seconds.
                              15756:20120717:112910.101 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'root'@'localhost' (using password: NO)
                              15756:20120717:112910.101 Database is down. Reconnecting in 10 seconds.
