process fails after completing startup?
  • Mark
    • Apr 2006
    • 9
    Hello;
    I'm new to Zabbix, and am trying to get it up and running for evaluation purposes. I'm tinkering with 1.1b9 on RH Enterprise 3, and it is doing the oddest thing:
    012609:20060427:111402 In housekeeping_alerts(1146154442)
    012609:20060427:111402 Executing query:select alert_history from config
    012609:20060427:111402 In DBnum_rows
    012609:20060427:111402 Result of DBnum_rows [1]
    012609:20060427:111402 Executing query:delete from alerts where clock<1114618442
    012609:20060427:111402 Deleted [0] records from table [alerts]
    012609:20060427:111402 In housekeeping_sessions(1146154442)
    012609:20060427:111402 Executing query:delete from sessions where lastaccess<1146068042
    012609:20060427:111402 Deleted [0] records from table [sessions]
    012609:20060427:111402 Sleeping for 1 hours
    012609:20060427:111402 One server process died. Shutting down...
    012609:20060427:111402 0. Killing PID=[12611]
    012609:20060427:111402 1. Killing PID=[12612]
    012609:20060427:111402 2. Killing PID=[12614]
    012609:20060427:111402 3. Killing PID=[12616]
    012609:20060427:111402 4. Killing PID=[12618]
    012609:20060427:111402 5. Killing PID=[12619]
    012609:20060427:111402 6. Killing PID=[12620]
    012609:20060427:111402 7. Killing PID=[12623]
    012618:20060427:111402 Server [5]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    012609:20060427:111402 8. Killing PID=[12624]
    012609:20060427:111402 9. Killing PID=[12625]
    012609:20060427:111402 ZABBIX server is down.
    012611:20060427:111402 Server [1]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    012612:20060427:111402 Server [2]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    012614:20060427:111402 Server [3]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    012619:20060427:111402 Server [6]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    012620:20060427:111402 Server [7]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    012623:20060427:111402 Server [8]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    012624:20060427:111402 Server [9]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    012625:20060427:111402 Server [10]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    It finishes starting up and its housekeeping, goes to sleep and immediately then dies. No one is sending a kill to any of the processes. The only odd bits about my configuration are that i'm using mysql 5 and this is a VMWare instance instead of a physical box.
    I don't have any other output being generated, so I'm at a loss as to what to try next. Any advise would be appreciated.
    Thanks,
    Mark
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Please send whole zabbix_server.log to me : a l e x @ z a b b i x . c o m
    Thanks.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Mark
      • Apr 2006
      • 9
      you've got mail. (unless exchange is down. Again...)
      Any luck reproducing the problem?
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Unfortunately the log file gave no clue. I do not know why ZABBIX server decided to die.
        Did you run it on a fresh database?
        Alexei Vladishev
        My Twitter
        • Mark
          • Apr 2006
          • 9
          Ran on a clean install of mysql 5.0. Am reverting back down to the 4 branch, and shall try dropping net-snmp next in the build.
          After that, I'm out of ideas. all the other libs are standard RH E3.
          • Mark
            • Apr 2006
            • 9
            Rebuilt using the mysql 4.1.18 rpm's, and its running. I guess I've stumbled onto some sort of incompatibility with 5.0.
            Thanks for the help!
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              Excellent news!
              Alexei Vladishev
              My Twitter
