I use the history.get API method to retrieve data from the database. Everything is fine. But I have an item which has "keep history" set to 60 days, and it seems that the history.get API won't retrieve data before 60 days... am I correct?
Then, how could I retrieve such data?
Thanks in advance.
EDIT:
If it matters, I'm using Zabbix v1.8.3.
Thanks in advance.
EDIT:
