Discovery actions not acting as expected.
  • clubbing80s
    • Sep 2005
    • 109
    Hi.
    I have upgraded to Zabbix 2.0.0 .
    The discovery is working and populating the dashboard discovery rules, and as far as I can tell the uptimes and down times are correct.
    But other than that is seems to be ignoring the actions associated with the discovery rules. I have a rule to add discovered hosts in a network to a group and this is not happening .
    Sample :
    Discovery rule :
    Discovery by proxy : no proxy
    IP range : 192.168.10.1-255
    Delay (in sec) : 10800
    Checks : ICMP ping (143)
    SSH
    Device uniqueness criteria IP address
    Enabled
    Action associated with this rule :
    Name : 192.168.10 Subnet discovery
    Type : (A) and (B)
    Conditions : (A) Discovery rule = "192.168.10 Subnet"
    (B) Discovery status = "Discovered"
    Action operations:
    Details : Add to host groups: DMZ-192.168.10
    I have also tried Discovery status = "up" as well. and this did not help. The other thing that may be not worthy is that the Discovery group is no longer being populated as it used to by default.
    What have I missed ? Broken in the upgrade process.
    G
  • tserreyn
    • Jun 2012
    • 26
    get it to work
    did you ever get this to work? So far I have been unable to get even a simple discovery working on zabbix 2.0.
