Prototype grapth in template screens?
  • ghillan
    • Jan 2012
    • 20
    Subject says all. I see thats possible to create a screens in a template and add graphs created in the template itself, but i cannot find a way to add graphs created using low level discovery (tipically for mounted filesystems of interface detection). Its even possible?
    Tnx in advance.
  • kderja
    • Oct 2012
    Best workaround ?
    I see only one way- create API script to create screens per host - not very clear and easy.
    • r00t
      • Nov 2012
      • 9
      I'm just testing Zabbix for the first time and I'm also missing such an option. I'd like an option to add discovered prototype graphs to screens.
      • aziasdad
        • Nov 2012
        Was hoping to see an answer for this as it's also something we are looking to do. Prototypes of graphs for discovered items is really a nice feature, but not being able to build screens at the template level from them is a bummer. Is anyone else trying to do this?
        • phil
          • Feb 2013
          Same requirement here
          Would definitely need to have that feature
