eth0 traffic incoming or outgoing not supported
  • luxpops
    • Apr 2006
    Hi I setup Zabbix 1.1 beta 9 and everything seems to works except that I need the incoming and outgoing traffic of my Ubuntu server
    on the template for the netloadin and netloadout it says not supported. I tried the net.if.in for the manual (in web GUI) but it says not supported again.
    how to I do to make Zabbix get data for my eth0??
  • rnuno
    • May 2006
    I'm having the same problem in a remote server all network information is "not suported" on the remote host.
    How can we fix this? tnx
    • btriem
      • Apr 2006
      • 30
      Ditto, same problem here. Have not found a solution yet.
      • grabber
        • Mar 2005
        • 85
        they are working for me.
        try using:
        net.if.in[eth0,bytes]
        and check out:
        http://www.zabbix.com/manual/v1.1/config_items.php
        for the variables
        • cthree
          • May 2006
          The templates are wrong. You'll need to cross reference the items defined in the templates (those Not Supported) and change them to match the docs or delete them.
          • kanour
            • May 2006
            • 105
            Just one more small question.
            There are items with key netloadxx for traffic monitoring. Are these items useless?
            1. If yes I will delete them and create new with key net.if.xx.
            2. IF no I will leave the netloadxx keys there and create new with key net.if.xx.
            • speckados
              • Nov 2004
              Incredible.
              Fresh install and store values on Templates are ITEMS that not' work?
              Think that it's proper on Beta o Alpha versions. Not on stable or production.
              • stever
                • Jun 2006
                • 36
                This is a 1.1 version of a new open source tool, give them a break ( and contribute your own updated templates). Yes, the templates should be changed, but its easy to make your own. After three weeks of using this tool, we love it here.
