Hello again, any help regarding the questions below would be gratefully received, thanks in advance. j
How can you “search” for acknowledged alarms? Can I build a report that will show all Acknowledged alarms
Can you print the history of each alarm or can you copy & paste.
In the system status table there are columns -Disaster, High & Average. Is it possible to rename these or are they hard coded?
Pease do not get me wrong - I am not lazy, I have spent 3 months configuring our system, but these simple questions are what I have found in day to day usage
Cheers J
Cheers J
