agent restart fails with "failed to add UserParameter: duplicate key"
  • harri
    • Nov 2010
    • 89
    Hi folks,
    Very often I see that zabbix agent fails to restart with
    1916:20120630:115521.265 Got signal [signal:15(SIGTERM),sender_pid:5019,sender_uid:0,re ason:0]. Exiting ...
    1916:20120630:115523.265 Zabbix Agent stopped. Zabbix 1.8.13 (revision 27486).
    5342:20120630:115529.524 Starting Zabbix Agent [dpcl082.ac.aixigo.de]. Zabbix 1.8.14 (revision 28454).
    5342:20120630:115529.525 failed to add UserParameter "3ware_raid[*]": duplicate key
    If I retry, then it works fine:
    5508:20120630:120126.247 Starting Zabbix Agent [dpcl082.ac.aixigo.de]. Zabbix 1.8.14 (revision 28454).
    5510:20120630:120126.247 agent #0 started [collector]
    5511:20120630:120126.247 agent #1 started[listener]
    5512:20120630:120126.247 agent #2 started[listener]
    5513:20120630:120126.247 agent #3 started[listener]
    5515:20120630:120126.248 agent #4 started [active checks]
    The config files (esp. the config file defining the 3ware_raid stuff) haven't changed, so how comes?
    Any helpful comment would be highly appreciated
    Harri
