Status "Not supported"
  • Zero_WISE
    • May 2006
    Hey. I'm new to Zabbix and having difficulties on post-install. Server- and Client-installation happened without a glich using online-manual. Adding hosts was also easy, Status on all of them is set to Monitored.
    My only problem is that I do not have any Triggers or anything. As far as I can see, the problem lies in Items. None of the added hosts are Active in Status, they all are set to "Not Supported".
    What is it that I'm missing? Help, help please.
  • grabber
    • Mar 2005
    • 85
    I had similar issue:
    the resolution was to increase the following entry in your php.ini file and restart.
    memory_limit=8M
    changed to
    memory_limit=16M
    hope that helps
    sorry I may have jumped the gun there but try it anyway and report back...if it does not help I'll try to walk you through some things....(Y)
    • Zero_WISE
      • May 2006
      Unfortunately it didn't work. It did made the frontend reply faster, but the problem remains.
      I've tried to do a fresh install of zabbix with pkg_add on my FreeBSD, just to see if there is any difference, but it's the same...
      • grabber
        • Mar 2005
        • 85
        just asking but have you made sure the zabbix_agent or zabbix_agentd is running on all your hosts and have you linked your hosts to a template? If you are using snmp can the server access the clients?
        • Zero_WISE
          • May 2006
          I'm using zabbix_agentd and they seem to work properly. When I look under Hosts, I can see that all of the servers I have, are set to "Monitored". I didn't install snmp, do I need to do this?
          The first server I'm trying to configure runs both server and agent; could this be an issue? They don't use the samme ports...
          I haven't been abble to set any UserParameters; is this neccesary or does zabbix have some defaults it monitors?
          I also found this in zabbix_suckerd.log: Parameter [1] is not supported by agent on host...
          What does it mean?
          • gedp
            • May 2006
            • 47
            I'm also new to zabbix, but could reply to your post: both the zabbix_server and the zabbix_agentd are running on the same box without problem. I did not had to configure the UserParameters to get it running. These should only be used for more specialised things.
            You're not confusing the zabbix_agent and the zabbix_agentd (with D)?
            • Zero_WISE
              • May 2006
              No, I'm 100% that I'm using zabbix_agentd
              • grabber
                • Mar 2005
                • 85
                What does it mean?
                you do not need to set up tany UserParameters yet. Have you copied over the zabbix_agentd.conf file to /etx/zabbix/zabbix_agentd.conf? and edited it to reflect your specific setup?
                from a console you could run: zabbix_agentd -p and check the opoutput....post it here if you can
                • Zero_WISE
                  • May 2006
                  No output whatsoever :S.
                  zabbix_agentd.log contains only this:
                  009909:20060505:122708 One child process died. Exiting ...
                  009910:20060505:122708 Got signal. Exiting ...
                  010807:20060505:122711 zabbix_agentd started
                  010808:20060505:122711 zabbix_agentd 10808 started
                  010809:20060505:122711 zabbix_agentd 10809 started
                  010810:20060505:122711 zabbix_agentd 10810 started
                  010811:20060505:122711 zabbix_agentd 10811 started
                  010812:20060505:122711 zabbix_agentd 10812 started
                  • grabber
                    • Mar 2005
                    • 85
                    well!
                    if you do ps -ef |grep zabbix
                    what do you get?
                    check your /etc/zabbix/zabbix_agentd.conf file...
                    • Zero_WISE
                      • May 2006
                      I got nothing...
                      I did this instead:
                      ps aux | grep zabbix
                      zabbix 9895 0.0 0.1 3840 3104 ?? I 10:14AM 0:00.03 zabbix_sucker
                      zabbix 9896 0.0 0.1 3840 3104 ?? S 10:14AM 0:00.11 zabbix_sucker
                      zabbix 9897 0.0 0.1 3840 3104 ?? S 10:14AM 0:00.09 zabbix_sucker
                      zabbix 9898 0.0 0.1 3840 3108 ?? S 10:14AM 0:00.13 zabbix_sucker
                      zabbix 9899 0.0 0.1 3840 3104 ?? S 10:14AM 0:00.06 zabbix_sucker
                      zabbix 9917 0.0 0.1 1892 1464 ?? I 10:14AM 0:00.00 zabbix_trappe
                      zabbix 9918 0.0 0.1 1892 1464 ?? I 10:14AM 0:00.00 zabbix_trappe
                      zabbix 9919 0.0 0.1 1892 1464 ?? I 10:14AM 0:00.00 zabbix_trappe
                      zabbix 9920 0.0 0.1 1892 1464 ?? I 10:14AM 0:00.00 zabbix_trappe
                      zabbix 9921 0.0 0.1 1892 1464 ?? I 10:14AM 0:00.00 zabbix_trappe
                      zabbix 9922 0.0 0.1 1892 1464 ?? I 10:14AM 0:00.00 zabbix_trappe
                      zabbix 10807 0.0 0.0 1520 1012 ?? IN 12:27PM 0:00.00 zabbix_agentd
                      zabbix 10808 0.0 0.0 1520 1012 ?? IN 12:27PM 0:00.00 zabbix_agentd
                      zabbix 10809 0.0 0.0 1520 1012 ?? IN 12:27PM 0:00.00 zabbix_agentd
                      zabbix 10810 0.0 0.0 1520 1012 ?? IN 12:27PM 0:00.00 zabbix_agentd
                      zabbix 10811 0.0 0.0 1520 1012 ?? IN 12:27PM 0:00.00 zabbix_agentd
                      zabbix 10812 0.0 0.0 1520 1012 ?? IN 12:27PM 0:00.00 zabbix_agentd
                      Here is my zabbix_agentd.conf
                      # IP address of Zabbix server. No spaces allowed.
                      Server=127.0.0.1
                      # Listen port. Default is 10000
                      ListenPort=10005
                      # IP address to bind agent
                      # If missing, bind to all available IPs
                      #ListenIP=127.0.0.1
                      # Number of pre-forked instances of zabbix_agentd.
                      # Default value is 5
                      # This parameter must be between 1 and 16
                      StartAgents=5
                      # Specifies debug level
                      # 0 - debug is not created
                      # 1 - critical information
                      # 2 - error information
                      # 3 - warnings (default)
                      # 4 - for debugging (produces lots of information)
                      DebugLevel=3
                      # Name of PID file
                      PidFile=/var/tmp/zabbix_agentd.pid
                      # Name of log file.
                      # If not set, syslog will be used
                      LogFile=/tmp/zabbix_agentd.log
                      # Spend no more than Timeout seconds on processing
                      # Must be between 1 and 30
                      Timeout=3
                      ##### Experimental options. Use with care ! #####
                      # Get rid of sockets in TIME_WAIT state
                      # This will set socket option SO_LINGER
                      # NoTimeWait=1
                      ##### End of experimental options
                      # Format: UserParameter=<key>,<shell command>
                      # Note that shell command should return numeric value
                      #UserParameter=system[test],who|wc -l
                      #UserParameter=queuelevel[901], sudo -H /usr/sbin/asterisk -rx 'show queues' | grep --text -i '901' | awk '{print $ 3}'
                      ### Set of parameter for monitoring MySQL server (v3.23.42 and later)
                      ### Change -u<username> and add -p<password> if required
                      • Zero_WISE
                        • May 2006
                        I read somewhere that zabbix isn't all that good at running both server and agent on same mashine.
                        Is this the truth? I sure hope it's not, then I can't use it
