having problem to setup the java gateway.
Installed server and java gateway on same machine and getting this exception.
2012-07-12 15:24:51.637 [pool-1-thread-4] DEBUG com.zabbix.gateway.SocketProcessor - dispatched request to class com.zabbix.gateway.JMXItemChecker
2012-07-12 15:24:51.637 [pool-1-thread-4] DEBUG com.zabbix.gateway.JMXItemChecker - connecting to JMX agent at service:jmx:rmi:///jndi/rmi://plns00011:12345/jmxrmi
2012-07-12 15:24:51.686 [pool-1-thread-4] WARN com.zabbix.gateway.SocketProcessor - error processing request
com.zabbix.gateway.ZabbixException: java.rmi.ConnectException: Connection refused to host: 127.0.0.1; nested exception is:
java.net.ConnectException: Connection refused
at com.zabbix.gateway.JMXItemChecker.getValues(JMXIte mChecker.java:100) ~[zabbix-java-gateway-2.0.1.jar:na]
at com.zabbix.gateway.SocketProcessor.run(SocketProce ssor.java:63) ~[zabbix-java-gateway-2.0.1.jar:na]
at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1110) [na:1.6.0_24]
at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:603) [na:1.6.0_24]
at java.lang.Thread.run(Thread.java:679) [na:1.6.0_24]
Caused by: java.rmi.ConnectException: Connection refused to host: 127.0.0.1; nested exception is:
