Hi, Quick question...
In my previous company we used NetCool for our monitoring.
This was configured to listen for alerts coming from the servers being monitored.
e.g.
Server_X would scan log files, like /var/adm/messages, and if there was a problem (e.g. "/var usage > 95%") that server would fire off a message to NetCool with some warning text and a severity alert level. Something like
["Warning: /var usage is > 90% (95%)", "3"]
(So, the "alert message, the (actual usage)" and "the severity level")
The NetCool display would then pop up an alert in the summary list with the appropriate colour/alert levels, etc.
My current company is using Zabbix and I was wondering if Zabbix is able to do the same sort of monitoring, e.g. reacting to an incoming alert from a server, rather than actively polling the server(s) for issues?
The zabbix server we're using (running 1.8.10) is getting a little sluggish these days, probably from all the hosts and services it's monitoring so I'm looking for ways to try and minimise the traffic in/out of the Zabbix server (as well as the servers being monitored)...
Cheers,
Rob.
e.g.
Cheers,
Rob.
