I have an equipment which can have several neighbours (other units). This number can vary.
For each neighbour I have about 20 OIDs configured / temperature etc.
I can manually add these OIDs for each equipment added. I can manually delete these OIDs for each equipment removed. But that's so time consuming...
I have an OID which tells me how many neighbours the equipment has. I could use a trigger which tells me about any change of the total count of these neighbours.
Can I somehow configure that in case that any equipment is removed from the network, these 20 OIDs are removed? And if any equipment is added, these 20 OIDs are also added again?
Thanks.
Thanks.
