Do Support Staff Help Out Here? Still cant start zabbix?
  • BigBirdy
    • May 2006
    • 25
    I just compiled and tried to start the 1.1 beta9 zabbix_server process on an RHES4 system and mysql 4.1.10, bit it doesnt seem to want to start? Have also tried on a fresh RHES3 system, with the same results?
    I am trying to run either with su or logged in as another user, but this is the message I get
    root@penguin:/usr/local/bin# su stork ./zabbix_server
    ./zabbix_server: ./zabbix_server: cannot execute binary file
    Permissions seem fine:
    root@penguin:/usr/local/bin# ls -la | grep zabbix
    drwxr-xr-x 2 zabbix zabbix 4096 May 8 10:45 zabbix
    -rwxr-xr-x 1 zabbix zabbix 184177 May 8 12:50 zabbix_agent
    -rwxr-xr-x 1 zabbix zabbix 252129 May 8 12:50 zabbix_agentd
    -rwxr-xr-x 1 zabbix zabbix 20396 May 8 12:50 zabbix_get
    -rwxr-xr-x 1 zabbix zabbix 29758 May 8 12:50 zabbix_sender
    -rwxr-xr-x 1 zabbix zabbix 1569955 May 8 12:50 zabbix_server
    root@penguin:/usr/local/bin# su zabbix zabbix_server
    zabbix_server: zabbix_server: cannot execute binary file
    And nothing gets logged to /tmp/zabbix.log
  • cameronsto
    • Oct 2005
    • 148
    Have you tried starting it without the 'su user' command in front of it? The zabbix binaries automatically assume the zabbix user when run.
    -cameron
    • ruckus37
      • Oct 2004
      • 57
      Have you tried running as root? (test)
      • ruckus37
        • Oct 2004
        • 57
        Do Support Staff Help Out Here is a very negative form for speech when referring too that Zabbix project, these guys do a tremendous job, try do a bit of research into the project before making that the heading of your topic..
        • grabber
          • Mar 2005
          • 85
          I am running it on CentOS 4.2 which is the same as RHEL4 update2
          what do you need?
          P.S. I am not support staff just another user
          • grabber
            • Mar 2005
            • 85
            just run zabbix_server as root the process forks to run as zabbix user.
            • BigBirdy
              • May 2006
              • 25
              Thanks everyone and I regret my choice of words. It was in no way meant to be negative. Rather, a pragmatic question to determine if the developers/owners/commercial side of Zabbix also monitor the forums. In my experience with products that have both a commercial and "free" or open-source product, or with tiered support, most demonstrate different levels of commitment to their "free" side. My question was not meant to critisize, only to understand/decide if I needed to purchase support at this early stage, or whether the mainline support staff also make contributions to the forums, like with the Scalix groupware product. So I apologize for any offence that my question generated, it was not intended.
              Now back to the problem at hand, have tried "su someuser" have tried as root, have compiled as another user (not root) and always exactly the same results "cannot execute binary file" very strange indeed.
              Maybe, if someone has some binaries compiled on RHES4, you could send them to me and I could try them? I am running 2.6.9-34.ELsmp.
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                We do read all posts and at least respond to all serious issues.
                Regarding you issue, can you start zabbix_server by user 'zabbix' or other user which compiled ZABBIX? Any errors?
                Alexei Vladishev
                New York | Tokyo | Riga
                My Twitter
                • DiedX
                  • Oct 2004
                  • 106
                  Also, while asleep I thought of the following:
                  Does your server use SELinux or something? Is there something in /var/log/messages?
                  Furthermore: x86 of x64?
                  https://www.diederik.nl
                  • BigBirdy
                    • May 2006
                    • 25
                    No errors or anything in syslog, and no matter which user I try to start with I get the same error
                    An selinux is disabled completly...very strange and system is x86 (Dual Athlon)
                    • DiedX
                      • Oct 2004
                      • 106
                      Can you give us the owner and group of the file? (ls -l /path/to/zabbix, probably /usr/local/bin)
                      (Own info: http://dev.eclipse.org/newslists/new.../msg50658.html)
                      • Alexei
                        Founder, CEO
                        • Sep 2004
                        • 5654
                        What if you run zabbix_server directly under user zabbix without doing 'su'?
                        Alexei Vladishev
                        My Twitter
