Dual zabbix server possible ?
  • hgomez
    • Jul 2012
    • 17
    Hi to all,
    I'm new to Zabbix and using 2.0.1 from OpenSuse.
    I should handle DRP problematics so I set up 2 zabbix servers on different locations.
    I set agent to know about both servers but only first one report agent / instance as monitored, second Zabbix server has still its Z in red mentioning agent closed connection ;(
    in zabbix-agentd.conf I've :
    Server=monitoring1.mycorp.com, monitoring2.mycorp.com
    No ServerActive defined.
    Did Zabbix agent could serve 2 Zabbix servers ?
    Thanks for your help
  • hgomez
    • Jul 2012
    • 17
    reply to myself :
    didn't works
    Server=monitoring1.mycorp.com,monitoring2.mycorp.c om
    works
    Frankly in 2012, stripping spaces is a general consensus
    Documentation said :
    ### Option: Server
    # List of comma delimited IP addresses (or hostnames) of Zabbix servers.
    # No spaces allowed. If ServerActive is not specified, the first entry is used
    # for receiving list of and sending active checks.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally.
    In this example, there is space after ,
