Monitoring is working, but everything under Administration and Configuration is gone
  • sippykup
    • Mar 2008
    We just had a database corruption issue where we had to rebuild the zabbix database by exporting all table data out to SQL files, and reimport into a new mysql database. After doing this, our zabbix UI is in this weird state, where the server seems to be working fine, alerts are going off as necessary, and data continues to be recorded. Graphs are updating normally, and display normally in the UI.
    But as soon as I click on the Configuration or Administration menus, everything is blank. Zabbix shows no users. It shows no hosts configured. It will let me add new users and new hosts, and they appear in the database when I add them, but still, nothing appears in the UI. It's just blank ("No users defined", "No hosts defined", etc.).
    It would appear that something went pretty wrong with the export/import, but browsing through the database, nothing obvious is jumping out at me. I wondered if anyone here had any idea what would cause this problem.
    Thanks.
