System.swap.size vs system.swap.in/out
  • JoelPettigrew
    • Jul 2012
    This is kind of a repost from Monday...
    I am pretty new to Linux and Unix. I walked into a position at a company that is using Zabbix to monitor percentage of system.swap.size. I was told that it might be a better indicator of problems by capturing system.swap.in/system.swap.out.
    Any suggestions or explanations would be really appreciated.
    Thanks!
    Joel
  • harmonica
    • Jan 2009
    • 251
    http://www.zabbix.com/documentation/...s/zabbix_agent
    Swap in (from device into memory) statistics.
    Swap out (from memory onto device) statistics.
    "Swap-in and Swap-out is the transfer of the whole content from main memory to virtual memory and vice-versa."
    • JoelPettigrew
      • Jul 2012
      That does help quite a bit. Is there a benefit to monitoring in and out vs space? Seems like regardless of what you monitor it has to be in context. Like if you monitor sectors, what is a way to define how many sectors for how long is bad?
      Are there good reasons to monitor in and out pages or sectors versus overall size as a percentage?
      Thanks again!
      Joel
