sum of processors on different hosts
  • tubik
    • Jul 2012
    how I can do sth like this:
    I have processes abc01, abc02 .. abc10, but they are on two hosts.
    for example: 1 on hostA 9 on hostB or 5 on hostA 5 on hostB, can me different on each day for example...
    The sum is 10 but how I can monitor this sum of processes on this hosts?
    I try some solutions but all of them not work.
    (Zabbix 1.8)
  • kasame
    • May 2012
    hi tubik,
    have you tried configuring on both host all ten processes because since you dont know which host will have how many processes then I would suggest configuring on both host all ten processes.
    HTH
    • tchjts1
      • May 2008
      • 1605
      I understand you are on 1.8, but if you were on 2.0 or later, you could do this with low level discovery:
      • tubik
        • Jul 2012
        Originally posted by kasame
        hi tubik,
        HTH
        but I have unnecessary alerts. I want check sum of processes on this two hosts
        And I have Zabbix 1.8 for monitor linux machines
        • tubik
          • Jul 2012
          I use grpsum and it's working.
          thread to close.
