Graph with fixed y-axis: Incorrect value
  • just2blue4u
    • Apr 2006
    • 347
    Hi!
    When creating a graph for showing me the net load, i get this error:
    Warning. Incorrect value for [yaxismax]
    I want to set yaxismax to 100M (100000000).
    If i set it to 100, the graph is created, but the line isn't shown (because min value is s.th. above 2K?).
    How to fix yaxismax to 100M(bit/s) ?
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
  • baz0r
    • Jun 2006
    I'm facing this same issue!
    I have just upgraded from 1.0 alpha to 1.1.
    Previously in 1.0a I used a fixed Y axis Max value for graphs so that I could more accuratly present RAM and Hard Disk sizes in graphs (using 'Calculated' graphs for items that have a fixed maximum value creates white space at the top of each graph and causes the axis labels to be less exact; 1.112 GB instead of 1024 MB for example).
    It seems that in 1.1 the yaxismax cannot be greater than 10000.0000 or near, but in version 1.0a I used very large numbers (1075000000.0000 for a fixed maximum of 1024 for example), to improve the accuracy of the graphs!
    I would like to know why this feature has been changed? It worked well in 1.0a (although it was tedious setting it for each graph, the graphs were alot clearer in the end!), so why has it been changed?
    There is also some scope to add a third option, instead of simply Fixed or Calculated, why not have a fixed option that detects a constant max value and sets that value as the maximum axis for the graph! That would greatly reduce the time it takes to setup many graphs using fixed y axis max!?
    Thoughts?
    • Lovespider
      • Sep 2004
      • 99
      Same for me using stable 1.1. Cannot set to display bandwidth of 2 millions bits per second -> 2000000.
      Can it be changed with a patch?
