Alright, so I'm working on setting up monitoring on a couple of Zimbra servers, and after much messing around I am finally able to SNMPWalk the server to obtain the following information.
iso.3.6.1.2.1.1.1.0 = STRING: "Linux officezimmail 2.6.32-41-server #91-Ubuntu SMP Wed Jun 13 11:58:56 UTC 2012 x86_64"
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.8072.3.2.10
iso.3.6.1.2.1.1.3.0 = Timeticks: (19080) 0:03:10.80
iso.3.6.1.2.1.1.4.0 = STRING: "[email protected]"
iso.3.6.1.2.1.1.5.0 = STRING: "myserver"
iso.3.6.1.2.1.1.6.0 = STRING: "mylocation"
iso.3.6.1.2.1.1.8.0 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.2.1 = OID: iso.3.6.1.6.3.10.3.1.1
iso.3.6.1.2.1.1.9.1.2.2 = OID: iso.3.6.1.6.3.11.3.1.1
iso.3.6.1.2.1.1.9.1.2.3 = OID: iso.3.6.1.6.3.15.2.1.1
iso.3.6.1.2.1.1.9.1.2.4 = OID: iso.3.6.1.6.3.1
iso.3.6.1.2.1.1.9.1.2.5 = OID: iso.3.6.1.2.1.49
iso.3.6.1.2.1.1.9.1.2.6 = OID: iso.3.6.1.2.1.4
iso.3.6.1.2.1.1.9.1.2.7 = OID: iso.3.6.1.2.1.50
iso.3.6.1.2.1.1.9.1.2.8 = OID: iso.3.6.1.6.3.16.2.2.1
iso.3.6.1.2.1.1.9.1.3.1 = STRING: "The SNMP Management Architecture MIB."
iso.3.6.1.2.1.1.9.1.3.2 = STRING: "The MIB for Message Processing and Dispatching."
iso.3.6.1.2.1.1.9.1.3.3 = STRING: "The management information definitions for the SNMP User-based Security Model."
iso.3.6.1.2.1.1.9.1.3.4 = STRING: "The MIB module for SNMPv2 entities"
iso.3.6.1.2.1.1.9.1.3.5 = STRING: "The MIB module for managing TCP implementations"
iso.3.6.1.2.1.1.9.1.3.6 = STRING: "The MIB module for managing IP and ICMP implementations"
iso.3.6.1.2.1.1.9.1.3.7 = STRING: "The MIB module for managing UDP implementations"
iso.3.6.1.2.1.1.9.1.3.8 = STRING: "View-based Access Control Model for SNMP."
iso.3.6.1.2.1.1.9.1.4.1 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.2 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.3 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.4 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.5 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.6 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.7 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.8 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.8 = No more variables left in this MIB View (It is past the end of the MIB tree)
root@monit:/home/jnorton# snmpwalk -Os -v 2c -c zimbra 10.10.15.70 .1.3.6.1.2.1.1.6.0
root@monit:/home/jnorton# snmpwalk -Os -v 2c -c zimbra 10.10.15.70 .1.3.6.1.2.1.1.9.1.2.8
root@monit:/home/jnorton# snmpwalk -Os -v 2c -c zimbra 10.10.15.70 .1.3.6.1.2.1.1.9.1.3.1
Zimbra MIBs
AGENTX-MIB.txt RFC1155-SMI.txt
BRIDGE-MIB.txt RFC1213-MIB.txt
DISMAN-EVENT-MIB.txt RFC-1215.txt
DISMAN-SCHEDULE-MIB.txt RMON-MIB.txt
DISMAN-SCRIPT-MIB.txt SCTP-MIB.txt
EtherLike-MIB.txt SMUX-MIB.txt
HCNUM-TC.txt SNMP-COMMUNITY-MIB.txt
HOST-RESOURCES-MIB.txt SNMP-FRAMEWORK-MIB.txt
HOST-RESOURCES-TYPES.txt SNMP-MPD-MIB.txt
IANA-ADDRESS-FAMILY-NUMBERS-MIB.txt SNMP-NOTIFICATION-MIB.txt
IANAifType-MIB.txt SNMP-PROXY-MIB.txt
IANA-LANGUAGE-MIB.txt SNMP-TARGET-MIB.txt
IANA-RTPROTO-MIB.txt SNMP-USER-BASED-SM-MIB.txt
IF-INVERTED-STACK-MIB.txt SNMP-USM-AES-MIB.txt
IF-MIB.txt SNMP-USM-DH-OBJECTS-MIB.txt
INET-ADDRESS-MIB.txt SNMPv2-CONF.txt
IP-FORWARD-MIB.txt SNMPv2-MIB.txt
IP-MIB.txt SNMPv2-SMI.txt
IPV6-ICMP-MIB.txt SNMPv2-TC.txt
IPV6-MIB.txt SNMPv2-TM.txt
IPV6-TCP-MIB.txt SNMP-VIEW-BASED-ACM-MIB.txt
IPV6-TC.txt TCP-MIB.txt
IPV6-UDP-MIB.txt TRANSPORT-ADDRESS-MIB.txt
NET-SNMP-AGENT-MIB.txt UCD-DEMO-MIB.txt
NET-SNMP-EXAMPLES-MIB.txt UCD-DISKIO-MIB.txt
NET-SNMP-EXTEND-MIB.txt UCD-DLMOD-MIB.txt
NET-SNMP-MIB.txt UCD-IPFWACC-MIB.txt
NET-SNMP-PASS-MIB.txt UCD-SNMP-MIB.txt
NET-SNMP-TC.txt UDP-MIB.txt
NET-SNMP-VACM-MIB.txt zimbra.mib
NOTIFICATION-LOG-MIB.txt zimbra_traps.mib
That's all fine and wonderful.. but I'm struggling getting anything to work on the Zabbix side of things. The Zimbra server trap/community is all setup correctly as near as I can tell.
This server is already added to Zabbix and monitored using a custom template, however I also would like to add monitoring via the SMNP protocal as the other methods we've been using aren't as reliable.
So I guess I'm wondering where I go from here? I have added the host with an IP and turned monitoring off as documentation says.. but I guess I'm confused as to how I define my items/triggers with the SNMP information.
Anyone shed some light on this? (I'm continuing to read through documentation)
Zimbra MIBs
