Zabbix and many SNMP itmes
  • maruscya
    • Jul 2007
    • 129
    Ciao All..
    I have a question about snmp and zabbix. I need check memory status of my servers.
    I run this command by console
    snmpwalk -v1 -c public localhost 1.3.6.1.4.1.232.6.2.14.11.1.4
    and this is the output
    SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.1 = INTEGER: 4
    SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.2 = INTEGER: 2
    SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.3 = INTEGER: 4
    SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.4 = INTEGER: 2
    ... many other lines...
    If i need check all memory bank i must create 64 items, and 64 triggers. I suppose that takes a lot of time and it is very boring task. When i have finished , i'll need add the same items to other 18 different servers ...
    Is there a way to check with a single command all 64 items ?
    AndreA
  • hwidjaja
    • Oct 2011
    • 15
    Can you use discovery rules?
    • maruscya
      • Jul 2007
      • 129
      Could you tell me more about this? An example will be very appreciate.
      • hwidjaja
        • Oct 2011
        • 15
        can you send me:
        • maruscya
          • Jul 2007
          • 129
          can you send me:
          Yes.... below the output command...
          root@vespo-hub-dev:~# snmpwalk -v1 -c public localhost 1.3.6.1.4.1.232.6.2.14.11.1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.1.1 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.1.2 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.1.3 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.1.4 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.1.5 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.1.6 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.1.7 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.1.8 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.1.9 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.2.1 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.2.2 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.2.3 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.2.4 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.2.5 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.2.6 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.2.7 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.2.8 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.1.2.9 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.1.1 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.1.2 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.1.3 = INTEGER: 3
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.1.4 = INTEGER: 4
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.1.5 = INTEGER: 5
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.1.6 = INTEGER: 6
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.1.7 = INTEGER: 7
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.1.8 = INTEGER: 8
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.1.9 = INTEGER: 9
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.2.1 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.2.2 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.2.3 = INTEGER: 3
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.2.4 = INTEGER: 4
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.2.5 = INTEGER: 5
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.2.6 = INTEGER: 6
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.2.7 = INTEGER: 7
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.2.8 = INTEGER: 8
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.2.2.9 = INTEGER: 9
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.1.1 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.1.2 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.1.3 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.1.4 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.1.5 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.1.6 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.1.7 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.1.8 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.1.9 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.2.1 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.2.2 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.2.3 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.2.4 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.2.5 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.2.6 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.2.7 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.2.8 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.3.2.9 = ""
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.1 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.2 = INTEGER: 4
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.5 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.6 = INTEGER: 4
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.7 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.8 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.1.9 = INTEGER: 4
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.2.1 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.2.2 = INTEGER: 4
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.2.3 = INTEGER: 4
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.2.4 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.2.5 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.2.6 = INTEGER: 4
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.2.7 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.2.8 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.4.2.9 = INTEGER: 4
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.1.1 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.1.2 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.1.3 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.1.4 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.1.5 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.1.6 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.1.7 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.1.8 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.1.9 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.2.1 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.2.2 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.2.3 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.2.4 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.2.5 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.2.6 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.2.7 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.2.8 = INTEGER: 1
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.5.2.9 = INTEGER: 2
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.1.1 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.1.2 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.1.3 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.1.4 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.1.5 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.1.6 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.1.7 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.1.8 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.1.9 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.2.1 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.2.2 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.2.3 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.2.4 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.2.5 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.2.6 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.2.7 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.2.8 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          SNMPv2-SMI::enterprises.232.6.2.14.11.1.6.2.9 = Hex-STRING: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          Thanks for your help !
          • hwidjaja
            • Oct 2011
            • 15
            Can you try the attached template?
            It contains discovery rules:
            MemModuleStatus1 - 1.3.6.1.4.1.232.6.2.14.11.1.4.1.<OID>
            MemModuleStatus2 - 1.3.6.1.4.1.232.6.2.14.11.1.4.2.<OID>
            New Items will be
            MemModuleStatus 1.<OID>
            MemModuleStatus 2.<OID>
            • hwidjaja
              • Oct 2011
              • 15
              Forgot to mention that I created it using Zabbix 2.0.2. Please try it on a testing environment first as I have not tested it working fine at my end.
              • maruscya
                • Jul 2007
                • 129
                Many thanks for your help.
                I have imported it , and i'll start to test today. I'll keep you update !
                AndreA
                NB: many.. many thanks again!
                • maruscya
                  • Jul 2007
                  • 129
                  It's works !!!
                  You save my life man !
                  • hwidjaja
                    • Oct 2011
                    • 15
                    Originally posted by maruscya
                    It's works !!!
                    Great, thanks for letting us know
