Displaying Trigger level at graphs
  • Crypty
    • Jul 2012
    • 80
    Hi all,
    I have a graph with RSS signal strength (dBm) which has negative values. If I use this trigger condition:
    {R:rss.last(#1)}<-70
    Then it works, because if it droppes under the 70 dBm level, it triggers a message.
    BUT, the line doesn't appear in the graph. The other triggers has a lining at the graph concerning the watched value, but not in here.
    Is that somehow connected with using negative value?
    I use Zabbix 1.8.12
    Thanks!
