My groups don't seem to be working in overview...
  • cbidwell
    • Aug 2006
    • 127
    Take a look at this image and tell me what you think here...
    Why are my servers all separated in the same grouping? Doesn't make sense to me. Running 2.0.2.
    All of these systems are in the linux group, using the same Linux template. Why are they separated here?
  • dreddrus
    • Sep 2010
    I had the same problem. You can manually edit file triggers.inc.php. In function get_triggers_overview() exist a line 1149 (for 2.0.2):
    PHP Code:
    'expandDescription' => true
    You can simply delete or comment it and all will be fine!
