How to monitor two machines behind the firewall/NAT
The latter option is to connect to the first client, and let him check the services on the internal network. The problem with this option is that you cannot check all services.
I actualy setup the first option, but it did not work. It still does not work.
I have server (Debian) running zabbix_server_1.1beta9
Internet
I have firewall (Debian) running zabbix_agentd_1.1beta9 (port 10050)
I have workstation (Win XP) behind firewall running zabbixagentdW32_1.1beta3 (port 10052)
On the firewall I have DNAT to workstation (Win XP) on port 10052
On the server I have setup port 10052 for that Win XP host
Firewall itself accepts port 10050
I know that the setup is definitely OK, but win XP agent does not want to work.
Firewall works without problem.
As I received reply that other version of agent and server should work I am lost.
Zabbix server ip 10.0.0.10
has host My_WinXP_Box with IP 10.0.20.20
internet
WinXP Client with ip 10.0.20.20 and the following zabbix_agentd.conf:
Server=10.0.0.10
Hostname=My_WinXP_Box
Your host on the zabbix server should also be called My_WinXP_Box and change the checks to Active checks. Now the monitored hosts will send their data to the zabbix server.
Offcourse the ip's should be changed to your public ip's.
So I tried to install zabbix_server on the local net. The windows agent does not probably work at all. Even on local net.
Is there any testing procedure?
The service is running the configuration file is:
# This is config file for zabbix_agentd
# To get more information about ZABBIX, go http://www.zabbix.com
# List of comma delimited IP addresses (or hostnames) of ZABBIX servers.
# No spaces allowed. First entry is used for sending active checks.
# Note that hostnames must resolve hostname->IP address and
# IP address->hostname.
Server=alssrv01
# Server port for sending active checks
ServerPort=10051
# Unique hostname. Required for active checks.
Hostname=als04
# Listen port. Default is 10050
ListenPort=10050
# IP address to bind agent
# If missing, bind to all available IPs
#ListenIP=127.0.0.1
# Number of pre-forked instances of zabbix_agentd.
# Default value is 5
# This parameter must be between 1 and 16
StartAgents=5
# How often refresh list of active checks. 2 minutes by default.
#RefreshActiveChecks=30
# Disable active checks. The agent will work in passive mode listening server.
#DisableActive=1
# Enable remote commands for ZABBIX agent. By default remote commands disabled.
#EnableRemoteCommands=1
# Specifies debug level
# 0 - debug is not created
# 1 - critical information
# 2 - error information
# 3 - warnings (default)
# 4 - for debugging (produces lots of information)
DebugLevel=3
# Name of PID file
PidFile=C:\zabbix_agentd.pid
# Name of log file.
# If not set, syslog will be used
LogFile=C:\zabbix_agentd.log
# Spend no more than Timeout seconds on processing
# Must be between 1 and 30
Timeout=25
# Format: UserParameter=<key>,<shell command>
# Note that shell command must not return empty string or EOL only
#UserParameter=system.test,who|wc -l
### Set of parameter for monitoring MySQL server (v3.23.42 and later)
### Change -u<username> and add -p<password> if required
#UserParameter=mysql.ping,mysqladmin -uroot ping|grep alive|wc -l
#UserParameter=mysql.uptime,mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T"
#UserParameter=mysql.threads,mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"Q"
#UserParameter=mysql.questions,mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -d"S"
#UserParameter=mysql.slowqueries,mysqladmin -uroot status|cut -f5 -d":"|cut -f1 -d"O"
#UserParameter=mysql.qps,mysqladmin -uroot status|cut -f9 -d":"
#UserParameter=mysql.version,mysql -V
Make sure if you use hostnames they resolve correctly. I suggest to use fixed ip addresses for testing and when everything works ok you can move to hostnames.
After you made the changes to the conf file, restart the zabbix service.
