Customize User Acounts
  • Pablo
    • May 2006
    • 24
    I´d like to create differents clients accounts that can only view certain graphs, maps and principally hosts or groups of hosts. I need to use Zabbix to provide monitoring to many clients and security restrictions are very important to me (client called A only can see the information in relation with his host B and he can´t see other hosts).
    ¿Is there any way to do this one?
    Thanks,
    Pablo
  • krusty
    • Oct 2005
    • 222
    Yes, go to the configuration tab and switch to users. Then select your user and add permission for this user. Make note that you have to know the hostid, itemid, screenid, graphid and so on. I hope the developer of zabbix will make some dropdown boxes where you can select host, graph, item, screen and so on in the next versions.
    • Pablo
      • May 2006
      • 24
      Ok, I´ve installed the new beta (9) and I can do it.
