Agent Secure communication?
  • mofo
    • Jul 2012
    Hi!
    I wonder if someone knows if the agent traffic is encrypted or if you can encrypt it. And in that cashe witch crypto is used?
    I would want to have a proxy agent send information over the internet but dont know if it's safe.
    We use zabbix server 1.8.13 and the same agent version.
    Thanks!
  • Perec
    • May 2012
    I do not believe that the connection between the agent and the server is encrypted.
    The way to encrypt the data is through a vpn.
    • m_gularte
      • Jul 2012
      • 85
      Hi!
      The agent traffic is not encrypted... yet.
      I Agree with mofo, you should use a vpn or.... The only thing i´ve read about that is:
      Join the friendly and open Zabbix community on our forums and social media platforms.
      But do not work with proxy and i never tested.
      Good Luck =x
