Units Problem with Big Values
  • acarr
    • Apr 2012
    • 11
    Hi all,
    I'm aggregating values from my systems from an application that reports back Gigabyte (GB) values.
    Unfortunately my aggregation values go into the Terabyte (TB) ranges. When Zabbix displays these, it incorrectly displays them as KGB's.
    I have tried to adjust the Custom Multiplier on these to attempt to convert them back to Bytes (B) for Zabbix to automatically comprehend these and deal with the units correctly, however unfortunately Zabbix's Numeric (Float) type won't hold a value this high. [Numeric (Float is enforced because it's a Aggregate item]
    Is there an alternative way to make this work, or simply the ability to turn off the scaling?
    This server is running Zabbix 2.0.
  • nilmar
    • Apr 2016
    Sorry, reply wrong.
    • Atsushi
      • Aug 2013
      • 2028
      Maybe, you might be able to realize if you add a unit of GB in blackList.
      Please try add 'GB' to blackList in include/func.inc.php:function convert_units().
