Database Growth suddenly
  • DanH
    • Aug 2012
    My Zabbix Database started to grow and take up all the disk space in the early hours of this morning. I cant see anything that would have caused it, no new items have been added that would make this impact?
    I have attached a screenshot of the disk usage of the past 1 months.
    Regards
    Dan
  • Colttt
    • Mar 2009
    • 878
    Are you sure thats the mysql-db?
    Use
    du -hs /*
    To find the biggest directory, and then use
    du -hs /biggestdirectory/*
    And so on..
    Debian-User
    Sorry for my bad english
    • DanH
      • Aug 2012
      Definitely the MySQL DB
      It's definitely the MySQL DB as its the ibdata1 file is the file that has been growing.
      I think I may have figured out what happened, I think it's because I upgraded zabbix not long ago to version 2.0.1 and when doing that I truncated the history table so that the DB upgrade script wouldn't take weeks to complete, when doing this the ibdata file doesn't get shrunk so I guess the DB must have grew again and filled the file then kept growing and ate all the space.
      I've truncated the history table again and it's stopped growing so I just need to shrink the file (which I know in MySQL you can't do) and then start monitoring the zabbix DB growth and look at what items I have and their frequencies.
      Cheers
      Dan
