Hi all
Today I created a simple new item.
The type was "Simple Check".
key="icmpping[<ip>,<count>,<interval>,<size>,<timeout>]".
Then I created a trigger link to the item in the template.
The status of the trigger in the template was enabled,and there's no error.
But when I saw the host which linked to that template,there's an error occured.
The error was "Trigger just added. No status update so far."
And the trigger was not worked.
I don't konw how to fix.I need some helps.Many thanks.
