Important: My English is google translator
Hi, I'm trying to monitor the Zimbra server, but am having some problems. See my backup script:
#!/bin/bash
check=$1
maxage=59
file='/tmp/zimbra_status'
filef='/tmp/f_zimbra_status'
zab='/usr/sbin/zabbix_agentd -t '
#check if file exists
if [[ -e $filef ]]
then
OLD=`stat -c %Z $filef`
NOW=`date +%s`
# if older then maxage, update file
if [[ `expr $NOW - $OLD` -gt $maxage ]]
then
sudo -u zimbra date > /tmp/f_zimbra_status
sudo -u zimbra /opt/zimbra/bin/zmcontrol status >> $filef
sudo -u zabbix cat $filef > $file
sudo -u zabbix date >> /home/tools/zmlog_escrito.log
sudo -u zabbix cat $filef >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,antispam Running]" >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,antivirus Running]" >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,ldap Running]" >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,logger Running]" >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,mailbox Running]" >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,mta Running]" >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,snmp Running]" >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,spell Running]" >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,stats Running]" >> /home/tools/zmlog_escrito.log
sudo -u zabbix $zab "vfs.file.regmatch[/tmp/f_zimbra_status,zmconfigd Running]" >> /home/tools/zmlog_escrito.log
sudo -u zimbra echo "---------------" >> /home/tools/zmlog_escrito.log
fi
fi
This script parses the run time was greater than 59 seconds (to control the amount of scans). He plays the return status of zimbra to a file. This file after I complete game to another file for the status of zimbra vai recording slowly and this could cause problems when reading the file for zabbix.
I put some lines to test the error happens.
The file return:
Fri Aug 24 16:38:01 BRT 2012
Host mail.dperfeito.com.br
antispam Running
antivirus Running
ldap Running
logger Running
mailbox Running
mta Running
snmp Running
spell Running
stats Running
zmconfigd Running
But the vfs.file.regmatch is returning 0 for the zabbix server. Running the test script locally on the command always returns 1 as it should.
Is there any other command that could read the file?
Had some other solution to monitor the services of zimbra?
#!/bin/bash
check=$1
maxage=59
if [[ -e $filef ]]
then
NOW=`date +%s`
then
fi
fi
The file return:
antispam Running
antivirus Running
ldap Running
logger Running
mailbox Running
mta Running
snmp Running
spell Running
stats Running
zmconfigd Running
