Cisco Nexus N7k Template
  • iNeedHelp99
    • Aug 2012
    Hi guys,
    Does anyone have the monitoring template for Cisco Nexus N7K? Tried to create on myself and uploaded into Zabbix but it says under the Status header "Not Supported"
    Anyone with a solution to this??
  • rbouchouka
    • Sep 2016
    I have the same problem, and I can not find a solution for the simple ping, it works very well pre-defined templat on version 2.4 but for temperature and CPU, I found nothing I'm really disappointed
