How To Monitor .exe software installed on window server 2008 with zabbix
  • imransafi
    • Aug 2012
    • 24
    Hello Dears...!
    I am new in Zabbix, I configured everything I need, Now I want to Monitor a .exe software logs by the name of Backup.exe located on my domain controller Windows Server 2008, Please let me know the steps to monitor that .exe software logs.
    With Best Regards,
    Imran Safi
    Network Engineer
    Kabul-Afghanistan
  • Colttt
    • Mar 2009
    • 878
    you can use proc.num..
    for example:
    proc.num[backup.exe]
    http://www.zabbix.com/documentation/...s/zabbix_agent
    Debian-User
    Sorry for my bad english
    • imransafi
      • Aug 2012
      • 24
      Shad0w
      Thanks for reply,
      I want to monitor the log of a software but this trick you mentioned shows 1 and 0 the availability of the .exe software.
      Can you please tell me the steps to monitor the log of software?
      Also don't forget to mention Type, Key and Type of Information while creating Item.
      I am sure type of information should be log.
      Regards,
