Zabbix agent rpm for red hat
  • ehermouet
    • May 2011
    • 50
    Hi all,
    i search zabbix agent which i can install on endian firewall based on red hat.
    anybody can help me ?
    tks advance
  • BDiE8VNy
    • Apr 2010
    • 680
    Take a look at http://www.kodai74.net
    • ehermouet
      • May 2011
      • 50
      tks for this it's appreciated
      now i miss
      libc.so.6(GLIBC_2.4) is needed by zabbix-agent-2.0.0-1.el5.i386
      libcrypto.so.6 is needed by zabbix-agent-2.0.0-1.el5.i386
      liblber-2.3.so.0 is needed by zabbix-agent-2.0.0-1.el5.i386
      libldap-2.3.so.0 is needed by zabbix-agent-2.0.0-1.el5.i386
      libssl.so.6 is needed by zabbix-agent-2.0.0-1.el5.i386
      rtld(GNU_HASH) is needed by zabbix-agent-2.0.0-1.el5.i386
      zabbix = 2.0.0-1.el5 is needed by zabbix-agent-2.0.0-1.el5.i386
      grrrr endian frewall...
      • BDiE8VNy
        • Apr 2010
        • 680
        What exactly is Your distribution or what is the output of the following command?
        [foo@bar ~]$ cat /etc/*release
        CentOS release 6.3 (Final)
        [foo@bar ~]$
        • ehermouet
          • May 2011
          • 50
          tks for your reply
          the only mean that i found is download file from this post and it's works
          http://www.efwsupport.com/index.php?topic=2657.0
          tks
