V2.0.2 snmp and cisco
  • Alex_SYB
    • Feb 2012
    • 133
    Hi
    Seems like the auto discovery for process snmp doesn't seemed to be working on cisco routers
    snmpwalk -c pp -v 2c dcsw1 HOST-RESOURCES-MIB::hrProcessorLoad
    doesn't work were are
    snmpwalk -c pp-v 2c dcsw1 1.3.6.1.4.1.9.9.109.1.1.1.1.5.1
    does work. So is hrProcessorLoad wrong..
    Does somebody have an template for cisco routers with discovery rules ?
  • ghillan
    • Jan 2012
    • 20
    Originally posted by Alex_SYB
    Hi
    I could be wrong but as far i can see the problem its not the router or zabbix. Infact you cand recognize the OID names with snmpwalk.The problem its simply that your linux box ( where you make snmpwalk) dont have the MIB for those OIDs. You should look for a MIB that include Cisco propietary OIDS and the use it when you use snmpwalk ( with -m ).
    • Alex_SYB
      • Feb 2012
      • 133
      hi
      no not really. But it is the wrong oid for a router.. That oid is for ... well I think a pc/server..
      Found the right oid
      This document seems to cover it
      http://www.cisco.com/en/US/tech/tk64...80094a94.shtml
      Alex
      • limo
        • Dec 2004
        • 192
        Cisco SNMP dynamic template
        Hi to all,
        I am sending working SNMP autodiscovery template for Cisco devices. It should work for other SNMP switches too. It supports interfaces monitoring, CPU, Temperature and Fans. Feel free to use. It can be used for L3 switches too but it does not include L3 informations. We tested on 2950s , 2960s, 6500, 3750 and some HP procurves.
        Should work in zabbix 2.0+
        • sabbirjoy
          • Sep 2012
          about snmp template
          Originally posted by limo
          Hi to all,
          I have tried actually to add your template in zabbix 2 for cisco devices. but when i am going to import this in template ,its not loading and showing so many errors. can you kindly look again... really ,it will be a great help for the community and specially for me if it works correctly
          • limo
            • Dec 2004
            • 192
            Please which errors it generates? For me it works good.
            • mbsit
              • Sep 2012
              • 130
              Hi
              There is bug in 2.0.0 when you try to import Templates.
              Upgrade at least frontend to the version 2.0.2
              Bests,
              Grzegorz
              Pozdrawiam
              Grzegorz Grabowski
              ____
              Wdrożenia, szkolenia, umowy serwisowe
              Warszawa - Polska
              • sabbirjoy
                • Sep 2012
                about cisco template
                hi limo , i got one suggestion from mbsit, i will try to upgrade my frontend, and after that if i get also the same problem ,i will write you with one screenshots to you for your convenience to analyze...
                • sabbirjoy
                  • Sep 2012
                  about enterasys switch
                  Hi to all,
                  hi, I am trying to find the snmp oid 1.3.6.1.4.1.5624.1.2.49.1.1.1.1.4 for enterasys switches to get its cpu load, and i got reply if i make a snmpwalk ,but if i put this snmp oid in zabbix ,its not giving me any value ,just saying "not supported and no such instance is currently exist"
                  Do you have any solution for that ?
                  • Ejdesgaard
                    • Aug 2013
                    Can't get Template_Cisco_SNMP_Autodiscovery to work
                    Hi zabbix community
                    First of all, i'm quite new to zabbix, but here goes.
                    I have added the template to a catalyst 3560 with the following configuration:
                    snmp-server user ROUSER ROGROUP v2c
                    snmp-server group ROGROUP v2c read ROVIEW access 10
                    snmp-server view ROVIEW mib-2 included
                    snmp-server view ROVIEW cisco included
                    snmp-server community ROCOMMUNITY RO 10
                    snmp ifmib ifindex persist
                    and I have changed the community strin from public to ROUSER in the template.
                    I have also changed the discovery_rule -> snmp_oid's on ifDescr and ifAlias, to IF-MIB::ifDescr and IF-MIB::ifAlias.
                    But the only information I get is "CPU" and "Simple Check"
                    If I on the other hand run:
                    snmpwalk 192.168.1.250 -v2c -c ROUSER IF-MIB::ifDescr
                    I get a list of all the interfaces on the switch, so the data is accessable, but doesn't show up in zabbix...
                    • limo
                      • Dec 2004
                      • 192
                      Functional template
                      Hi to all,
                      template is just working for us. I am sending latest version. Please note. It is critical to set regular expressions filter before importing template. Look into attached pic.
                      So, define regexp conditions, import template and enjoy. Main problem is that discovery finds even interfaces which has not all snmp values included (like null). So you have to filter it during discovery.
                      • jackal
                        • Dec 2016
                        Hi to all,
                        hi
                        I test to import the template to zabbix server,
                        made a group with name 'cisco' firstly.
                        and made a conditions likes your note.
                        but got a error when importing the file:
                        Empty filter condition macro for discovery rule "Interfaces descriptions".
                        how to solved?
                        thanks a lot.
