In the email from a trigger alarm, I'd really like to include an arbitrary string that's pulled from each machine. It's acquired using the item "system.run[echo $VARIABLE]" on each machine.
According to the zabbix man, this should be able to be accomplished using:
{host:key.func(param)}
But how do you use this? I tried various things like:
{{HOSTNAME}:{"system.run[echo $VARIABLE"}.last(0)}
Inside the body of an action, but can't get it to display. Any idea how I can get any email from this trigger to display this value? Can it only be integrated into the actual trigger?
