Zabbix + Stunnel
  • elextra
    • Sep 2012
    Zabbix + Stunnel
    Is there a way to secure the communication between a Zabbix server and a Zabbix agent?
    From what I have read on the net, people have suggested the use of stunnel with a Zabbix proxy configuration.
    While I can understand how that could work, it does not solve my problem as the communication between the zabbix agent and the zabbix proxy will still be in the clear. (although the communication from the proxy into the server will be encrypted).
    What I would like to achieve is to have an stunnel client on the zabbix agent and an stunnel server on the zabbix server.
    Problem: I am missing the port (see below XXX) the stunnel client will be listening to, in order to intercept Zabbix agent reply to the server.
    On Zabbix Agent machine, stunnel client
    ; to get requests from zabbix server and forward to the zabbix agent
    client = yes
    accept= 10051
    connect= 10052
    ; to intercept zabbix agent's reply to the zabbix server
    accept= XXX
    Connect= ZABBIX_SERVER_IP:11162
    On Zabbix Server machine, stunnel:
    accept= 11162
    connect= 10050
    My Zabbix client listens on port 10051
    My Zabbix server listens on port 10050
    The Command does not return anything...:
    zabbix_get -s AGENT_IP_MACHINE -p 10051 -k "system.cpu.util[,user,avg1]"
    I am using Zabbix 1.8.x.
    Many thanks,
    Elextra--
