Zabbix Proxy
  • nabberuk
    • May 2010
    • 82
    Zabbix Proxy
    I'm a little confused on the setup of a zabbix proxy. I have both installed and running, but a little unsure on the config.
    Say i have the following;
    Zabbix Server with an external IP: 123.123.123.123.
    Zabbix Proxy inside a network where the external IP changes.
    On the server i've gone to DM and added the Proxy, i can that the last seen is now filled in meaning the proxy is talking to the server.
    Now when added a host that's on the proxy, what do i put for the ip or dns?
    Is that the internal IP of the host?
  • nabberuk
    • May 2010
    • 82
    So installing an agent that will point to a proxy that points to a zabbix server.
    Zabbix Server Name: Would this be the hostname of the server i'm installing on agent on that needs to match up with the host on the front end?
    Agent Port: 10050
    Remote Command: Disabled
    Active Server: Would this also be the proxy?
    thanks,
    Nathan
