Zabbix sender multiple key values
  • esawyja
    • Dec 2011
    • 54
    Hi All,
    Can I define one item, eg sdp.status.???? and then send the statuses with zabbix_sender as below
    zabbix_sender -vvv -c /etc/zabbix/zabbix_agentd.conf -i sendsdp.txt
    Info from server: "Processed 0 Failed 4 Total 4 Seconds spent 0.000067"
    sent: 4; skipped: 0; total: 4
    cat sendsdp.txt
    TestServer sdp.status.0 6
    TestServer sdp.status.1 2
    TestServer sdp.status.2 0
    TestServer sdp.status.3 3
    Or must I define one item per sdp eg
    sdp.status.0
    sdp.status.1
    If I can assign muliple values to one key, what would the ??? be? I tried this
    sdp.status.[0,1,2,3], but this does not work
    Any suggestions please
  • JBo
    • Jan 2011
    • 310
    No.
    sdp.status.0
    sdp.status.1
    Yes
    Hope this helps
    JBo
    • esawyja
      • Dec 2011
      • 54
      Short and sweet...
      thanks!!
