I'm having trouble getting zabbix to reliably use my usermacros I've set for name, auth, and priv.
Letter for letter, here is what I have in the Macro config
{$SNMPV3_AUTH}
{$SNMPV3_NAME}
{$SNMPV3_PRIV}
And each have their corresponding value saved.
Strangely {$SNMP_COMMUNITY} has no issues with SNMPv2c.
I am aware about the SHA/AES limitation of zabbix, and I am able to sucessfully walk the devices with MD5/DES from my workstation.
Another pacularity is that the settings I have for Discovery on v3 have no issue walking the v3 settings or v2c for that matter.
I have the three v3 macros in templates (attatched) which are included in my test host which is failing to gather any info. If I put the values directly into the template, I have no issues as far as I can tell.
Below is an excerpt from my verbose zabbix server log:
I'm running zabbix 2.0.2 freshly compiled, thanks for any help
{$SNMPV3_AUTH}
{$SNMPV3_NAME}
{$SNMPV3_PRIV}
tail -f /var/log/zabbix/zabbix_server.log |grep SNMP
9606:20120913:193024.790 In substitute_simple_macros() data:'{$SNMP_COMMUNITY}'
9606:20120913:193024.790 In DCget_user_macro() macro:'{$SNMP_COMMUNITY}'
9606:20120913:193024.790 In DCget_host_macro() macro:'{$SNMP_COMMUNITY}'
9606:20120913:193024.791 In DCget_global_macro() macro:'{$SNMP_COMMUNITY}'
9606:20120913:193024.792 SNMP [NN*[email protected]:161]
9606:20120913:193030.987 SNMPv3 [[email protected]:161]
9580:20120913:193042.454 In substitute_simple_macros() data:'{$SNMP_COMMUNITY}'
9580:20120913:193042.454 In DCget_user_macro() macro:'{$SNMP_COMMUNITY}'
9580:20120913:193042.454 In DCget_host_macro() macro:'{$SNMP_COMMUNITY}'
9580:20120913:193042.455 In DCget_host_macro() macro:'{$SNMP_COMMUNITY}'
9580:20120913:193042.455 In DCget_global_macro() macro:'{$SNMP_COMMUNITY}'
9580:20120913:193042.457 In substitute_key_macros() data:'SNMPv2-MIB::sysUpTime.0'
9580:20120913:193042.457 End of substitute_key_macros():SUCCEED data:'SNMPv2-MIB::sysUpTime.0'
9580:20120913:193042.458 In get_value_snmp() key:'sysUpTime' oid:'SNMPv2-MIB::sysUpTime.0'
9580:20120913:193042.458 SNMP [NN*[email protected]:161]
9580:20120913:193042.473 In snmp_normalize(oid:SNMPv2-MIB::sysUpTime.0)
9580:20120913:193042.473 End of snmp_normalize():SNMPv2-MIB::sysUpTime.0
9580:20120913:193042.473 In get_snmp() oid:'SNMPv2-MIB::sysUpTime.0'
9606:20120913:193042.541 In substitute_simple_macros() data:'{$SNMP_COMMUNITY}'
9606:20120913:193042.541 In DCget_user_macro() macro:'{$SNMP_COMMUNITY}'
9606:20120913:193042.542 In DCget_host_macro() macro:'{$SNMP_COMMUNITY}'
9606:20120913:193042.543 In DCget_global_macro() macro:'{$SNMP_COMMUNITY}'
9606:20120913:193042.547 SNMP [NN*[email protected]:161]
9606:20120913:193048.742 SNMPv3 [[email protected]:161]
9583:20120913:193059.067 In substitute_simple_macros() data:'{$SNMPv3_NAME}'
9583:20120913:193059.067 In DCget_user_macro() macro:'{$SNMPv3_NAME}'
9583:20120913:193059.068 In DCget_host_macro() macro:'{$SNMPv3_NAME}'
9583:20120913:193059.068 In DCget_global_macro() macro:'{$SNMPv3_NAME}'
9583:20120913:193059.069 End substitute_simple_macros() data:'{$SNMPv3_NAME}'
9583:20120913:193059.069 In substitute_simple_macros() data:'{$SNMPv3_AUTH}'
9583:20120913:193059.069 In DCget_user_macro() macro:'{$SNMPv3_AUTH}'
9583:20120913:193059.070 In DCget_host_macro() macro:'{$SNMPv3_AUTH}'
9583:20120913:193059.071 In DCget_global_macro() macro:'{$SNMPv3_AUTH}'
9583:20120913:193059.071 End substitute_simple_macros() data:'{$SNMPv3_AUTH}'
9583:20120913:193059.072 In substitute_simple_macros() data:'{$SNMPv3_PRIV}'
9583:20120913:193059.072 In DCget_user_macro() macro:'{$SNMPv3_PRIV}'
9583:20120913:193059.072 In DCget_host_macro() macro:'{$SNMPv3_PRIV}'
9583:20120913:193059.073 In DCget_global_macro() macro:'{$SNMPv3_PRIV}'
9583:20120913:193059.073 End substitute_simple_macros() data:'{$SNMPv3_PRIV}'
9583:20120913:193059.074 In substitute_key_macros() data:'SNMPv2-MIB::sysUpTime.0'
9583:20120913:193059.074 End of substitute_key_macros():SUCCEED data:'SNMPv2-MIB::sysUpTime.0'
9583:20120913:193059.075 In get_value_snmp() key:'sysUpTime' oid:'SNMPv2-MIB::sysUpTime.0'
9583:20120913:193059.257 SNMPv3 [{$SNMPv3_NAME}@10.0.4.10:161]
9583:20120913:193059.258 In snmp_normalize(oid:SNMPv2-MIB::sysUpTime.0)
9583:20120913:193059.258 End of snmp_normalize():SNMPv2-MIB::sysUpTime.0
9583:20120913:193059.259 In get_snmp() oid:'SNMPv2-MIB::sysUpTime.0'
9606:20120913:193100.300 In substitute_simple_macros() data:'{$SNMP_COMMUNITY}'
