Need Help creating a Trigger with Text a Time values
  • tomcat.cdm
    • Jul 2012
    I have created some UserParamenters for a system than returns a "Healthy" or other value for non healthy. This a Text/String.
    I tried with no luck to create a Trigger that if the Text/String "Healthy" is found for more than N times or N seconds, trigger an alarm.
    The best I could was
    .status.regexp(healthy)#1
    Wich trigger right away the value was changed.
    I need to add to this Trigger a N times or N seconds from last "Healthy" result but I couldn't.
    Thank you!
