Snmp - HP Proliant & Mibs
  • anunez
    • Aug 2013
    • 43
    #16
    Originally posted by kevind
    OK, can't upload them here, so here are some links:
    Template_HP_SNMP_Agents (for HP blades & servers):
    http://goput.it/v/y4f.xml
    Template_HP_Chassis (for HP Bladecenters):
    http://goput.it/v/rnv.xml
    -Kevin
    estimated
    at the time of the import template tells me: Template_SNMP_traps
    • BaT
      • Dec 2013
      -Kevin
      Thanks a lot for your work, Kevin and for posting templates again! Are those the latest from your development? I assume that over two years since you've posted them originally you may improved it farther?
      Also, I may be doing smth. stupid, but together with the previous commentator I get the following error with Zabbix 2.0.9:
      Cannot import template "Template_HP_SNMP_Agent", linked template "Template_SNMP_traps" does not exist.
      Where that template comes from?
      Regards,
      BaT
      • drucej31
        • Aug 2014
        • 15
        #18
        Template_SNMP_Traps
        Did anyone get anywhere with this issue on importing the HP_SNMP.xml template that go posted... When i try and import this template into our Zabbix environment which is v2.0.11 i get this error..
        Now obviously the reason for the error is because this template does not exist, i just don't where to find it to ensure it can import successfully. I'm trying to get SNMP working on Zabbix with HP DL servers + C7000 blade enclosure unfortunately none of the Wiki templates work as they appear to be valid with version 1.8..
        • kevind
          • Sep 2011
          • 40
          #19
          I was finally able to create an account on the Zabbix wiki, so I posted it there on the Servers section of the Templates page. This version doesn't have a linked template. Here's a direct link to the file:
          Join the friendly and open Zabbix community on our forums and social media platforms.
          • evertonbernardi
            • Sep 2014
            • 10
            #20
            https://www.zabbix.org/mw/images/0/0...SNMP_Agent.xml
            First of all thanks for this great piece of work!
            I tried to import this template but received the error below:
            ERROR: Import failed
            Created: Application "Drive Array" on "Template_HP_SNMP_Agent".
            Created: Application "HP SNMP Agent" on "Template_HP_SNMP_Agent".
            Cannot find value map "cpqCondition" used for item "Drive Array Accelerator Condition" on "Template_HP_SNMP_Agent".
            What am I doing wrong?
            Regards!
            • kevind
              • Sep 2011
              • 40
              #21
              Zabbix has "issues" with value maps; I don't know a way to export/import them, I believe they need to be entered manually. I'll guess that you're using Zabbix 2.2 which I think won't let you import a template which references a value map if the map doesn't exist. It should be possible to hand-edit the template xml file to get rid of the value maps, but better to enter them so that you can see meaningful data instead of raw numbers.
              Here are the value maps that I use (FYI the mappings come from the SNMP MIB files).
              cpqCondition
              1 ⇒ other
              2 ⇒ OK
              3 ⇒ degraded
              4 ⇒ failed
              cpqDaAccelStatus
              1 ⇒ other
              2 ⇒ invalid
              3 ⇒ enabled
              4 ⇒ tmpDisabled
              5 ⇒ permDisabled
              cpqDaCntlrDriveWriteCacheState
              1 ⇒ other
              2 ⇒ disabled
              3 ⇒ enabled
              cpqDaCntlrModel
              1 ⇒ other
              2 ⇒ ida
              3 ⇒ idaExpansion
              4 ⇒ ida-2
              5 ⇒ smart
              6 ⇒ smart-2e
              7 ⇒ smart-2p
              8 ⇒ smart-2sl
              9 ⇒ smart-3100es
              10 ⇒ smart-3200
              11 ⇒ smart-2dh
              12 ⇒ smart-221
              13 ⇒ sa-4250es
              14 ⇒ sa-4200
              15 ⇒ sa-integrated
              16 ⇒ sa-431
              17 ⇒ sa-5300
              18 ⇒ raidLc2
              19 ⇒ sa-5i
              20 ⇒ sa-532
              21 ⇒ sa-5312
              22 ⇒ sa-641
              23 ⇒ sa-642
              24 ⇒ sa-6400
              25 ⇒ sa-6400em
              26 ⇒ sa-6i
              27 ⇒ sa-generic
              29 ⇒ sa-p600
              30 ⇒ sa-p400
              31 ⇒ sa-e200
              32 ⇒ sa-e200i
              33 ⇒ sa-p400i
              34 ⇒ sa-p800
              35 ⇒ sa-e500
              36 ⇒ sa-p700m
              37 ⇒ sa-p212
              38 ⇒ sa-p410
              39 ⇒ sa-p410i
              40 ⇒ sa-p411
              41 ⇒ sa-b110i
              42 ⇒ sa-p712m
              43 ⇒ sa-p711m
              44 ⇒ sa-p812
              45 ⇒ sw-1210m
              cpqDaLogDrvFaultTol
              1 ⇒ other
              2 ⇒ none
              3 ⇒ mirroring
              4 ⇒ dataGuard
              5 ⇒ distribDataGuard
              7 ⇒ advancedDataGuard
              8 ⇒ raid50
              9 ⇒ raid60
              cpqDaLogDrvStatus
              1 ⇒ other
              2 ⇒ ok
              3 ⇒ failed
              4 ⇒ unconfigured
              5 ⇒ recovering
              6 ⇒ readyForRebuild
              7 ⇒ rebuilding
              8 ⇒ wrongDrive
              9 ⇒ badConnect
              10 ⇒ overheating
              11 ⇒ shutdown
              12 ⇒ expanding
              13 ⇒ notAvailable
              14 ⇒ queuedForExpansion
              15 ⇒ multipathAccessDegraded
              16 ⇒ erasing
              cpqDaPhyDrvStatus
              1 ⇒ other
              2 ⇒ ok
              3 ⇒ failed
              4 ⇒ predictiveFailure
              5 ⇒ erasing
              6 ⇒ eraseDone
              7 ⇒ eraseQueued
              cpqTruthValue
              1 ⇒ false
              2 ⇒ true
              • mulbzh
                • Nov 2014
                • 115
                #22
                hello,
                there is no value 28 for cpqDaCntlrModel in your post
                and value 6 for cpqDaLogDrvFaultTol
                • mulbzh
                  • Nov 2014
                  • 115
                  #23
                  I tried Template but i have many errors :
                  425:20141126:102433.779 item "SSGH12:cpqDaPhyDrvReads.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1425:20141126:102433.786 item "SSGH12:cpqDaPhyDrvReads.0.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1425:20141126:102433.786 item "SSGH12:cpqDaPhyDrvReads.0.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1425:20141126:102433.786 item "SSGH12:cpqDaPhyDrvReads.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1425:20141126:102433.786 item "SSGH12:cpqDaPhyDrvWrites.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1425:20141126:102433.786 item "SSGH12:cpqDaPhyDrvWrites.0.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1425:20141126:102433.786 item "SSGH12:cpqDaPhyDrvWrites.0.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1425:20141126:102433.786 item "SSGH12:cpqDaPhyDrvWrites.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1425:20141126:102504.076 item "SSGH12:RandomWriteRatePctMax" became not supported: Cannot evaluate function "avg(#3)": item "SSGH12:cpqDaPhyDrvWrites.0.0" not supported.
                  1425:20141126:102514.165 item "SSGH12:vfs.file.regmatch["/etc/init.d/snmpd","^OPTIONS=\"-Lsd","*"]" became not supported: Cannot open file: [2] No such file or directory
                  1421:20141126:103233.747 item "SSGH12:cpqDaAccelCondition.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.747 item "SSGH12:cpqDaAccelStatus.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.747 item "SSGH12:cpqDaAccelWriteCachePercent.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaCntlrDriveWriteCacheState.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaCntlrPerfAvgLatency.0.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaLogDrvCondition.0.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaLogDrvFltTol.0.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaLogDrvPerfAvgQueueDepth.0.1.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaLogDrvStatus.0.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaPhyDrvCondition.0.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaPhyDrvCondition.0.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaPhyDrvStatus.0.0" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqDaPhyDrvStatus.0.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqHeFltTolFanCondition.0.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  1421:20141126:103233.748 item "SSGH12:cpqHeFltTolFanCondition.1.1" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
                  SNMP from zabbix server to Hp server is OPEN
                  for example if i try cpqDaPhyDrvCondition.0.0 (OID is 1.3.6.1.4.1.232.3.2.5.1.1.37.0.0)
                  snmpwalk ssgh12 -v2c -c public 1.3.6.1.4.1.232.3.2.5.1.1.37.0.0
                  -> there is no errors but no results
                  • kevind
                    • Sep 2011
                    • 40
                    #24
                    "there is no value 28 for cpqDaCntlrModel in your post
                    and value 6 for cpqDaLogDrvFaultTol"
                    That's because those values are not defined in the MIB
                    "I tried Template but i have many errors"
                    This template was designed to be uses with HP BL and DL series servers (blades and pizza boxes), and has been tested with G6, G7, and G8 series servers. In our case the servers always have an IDA controller and 2 drives. If you have some other configuration you may need to change/disable any items that don't apply to your hardware.
                    If your server has an IDA controller, you can see what your hardware supports by walking the CPQIDA-MIB (you'll first need to copy the mib file to its proper location, i.e. /usr/share/snmp/mibs for CentOS/RHEL)
                    snmpwalk -v 2c -c public server-name-or-ip CPQIDA-MIB::cpqDriveArray
                    What kind of equipment are you using it with that is generating the errors?
                    • mulbzh
                      • Nov 2014
                      • 115
                      #25
                      i have a DL 180 G6 server !
                      I have not copied the MIB in my zabbix server, i have to add this mib "CPQIDA-MIB" ?
                      • troffasky
                        • Jul 2008
                        • 634
                        #26
                        Yes, you'd need the MIB files if the SNMP OID is not numeric.
                        • kevind
                          • Sep 2011
                          • 40
                          #27
                          Your issue might be that your server doesn't have a Drive Array controller installed; if that's the case the CPQ-IDA mib won't help, and you'll want to remove or disable the Drive Array items in the template.
                          If you have the CPQSTDEQ-MIB installed, you can see what hardware is installed in your server:
                          snmpwalk -v 2c -c public server-name-or-ip-address CPQSTDEQ-MIB::cpqStdEquipment | less
                          If you have a Drive Array controller installed, the result will include something like this:
                          CPQSTDEQ-MIB::cpqSePciSlotBoardName.2.0 = STRING: "HP Smart Array P420i Controller"
                          On CentOS/RHEL, mib files can be installed by copying them to /usr/share/snmp/mibs
                          I usually get the mib files from an HP support pack, but they are available for download from a number of sites such as:
                          circitor,cafuro,winagentlog,e-verbe,snmp,syslog,eventlog,freeware,trap,eventlog,microsoft,mib,browser,smi,receiver,sender,get,set,next,scanner,asn1,asn.1,
                          • mihael_keehl
                            • Jun 2015
                            tried downloading both MIBs, but when I do an snmptranslate or snmpwalk it says "CPQSTDEQ-MIB::cpqDaNw3xDriverStatTable: Unknown Object Identifier" for example. How do I rectify this one?
