Sooo.. I'm learning how this dynamic index works now, and it's absolutely fantastic. I just added individual process graphing for my machine.
I noticed, though, that there are multiple values returned by my snmpwalk and I'm not sure if I am graphing it properly, looks like it's grabbing the first value and not looking any further.
So I want to monitor many things, Apache2 is an example:
So I see these processes running:
and here is the memory usage:
I start graphing this OID:
and it is consistently recording "20.96 Mbytes"
so..
is my apache really only taking 20.96 MB? That does sound realistic, but I want your opinion on the matter, because there are multiple "apache2" OID's in the hrSWRunPath OID. This machine is running, but there is extremely little webtraffic on it at all. Adding up all the OIDs gives me 91.9 MB just adding them up with a calculator. Enlighten? Thanks in advance!
.1.3.6.1.2.1.25.4.2.1.4.1 = STRING: "init" .1.3.6.1.2.1.25.4.2.1.4.2 = STRING: "kthreadd/136" .1.3.6.1.2.1.25.4.2.1.4.3 = STRING: "khelper/136" .1.3.6.1.2.1.25.4.2.1.4.40 = STRING: "init-logger" .1.3.6.1.2.1.25.4.2.1.4.180 = STRING: "upstart-socket-bridge" .1.3.6.1.2.1.25.4.2.1.4.233 = STRING: "/usr/sbin/sshd" .1.3.6.1.2.1.25.4.2.1.4.320 = STRING: "/sbin/syslogd" .1.3.6.1.2.1.25.4.2.1.4.354 = STRING: "/usr/sbin/saslauthd" .1.3.6.1.2.1.25.4.2.1.4.355 = STRING: "/usr/sbin/saslauthd" .1.3.6.1.2.1.25.4.2.1.4.402 = STRING: "sendmail: MTA: accepting connections" .1.3.6.1.2.1.25.4.2.1.4.4187 = STRING: "cron" .1.3.6.1.2.1.25.4.2.1.4.4420 = STRING: "/usr/sbin/xinetd" .1.3.6.1.2.1.25.4.2.1.4.4602 = STRING: "upstart-udev-bridge" .1.3.6.1.2.1.25.4.2.1.4.4604 = STRING: "/sbin/udevd" .1.3.6.1.2.1.25.4.2.1.4.4699 = STRING: "/usr/sbin/named" .1.3.6.1.2.1.25.4.2.1.4.7058 = STRING: "/usr/bin/memcached" .1.3.6.1.2.1.25.4.2.1.4.7487 = STRING: "/usr/sbin/apache2" .1.3.6.1.2.1.25.4.2.1.4.10382 = STRING: "/usr/sbin/apache2" .1.3.6.1.2.1.25.4.2.1.4.10397 = STRING: "/usr/sbin/apache2" .1.3.6.1.2.1.25.4.2.1.4.12840 = STRING: "/usr/sbin/mysqld" .1.3.6.1.2.1.25.4.2.1.4.21398 = STRING: "sshd: root@pts/0" .1.3.6.1.2.1.25.4.2.1.4.21411 = STRING: "-bash" .1.3.6.1.2.1.25.4.2.1.4.21813 = STRING: "/usr/sbin/apache2" .1.3.6.1.2.1.25.4.2.1.4.21814 = STRING: "/usr/sbin/apache2" .1.3.6.1.2.1.25.4.2.1.4.27021 = STRING: "/usr/sbin/snmpd" .1.3.6.1.2.1.25.4.2.1.4.27927 = STRING: "sshd: root@pts/2" .1.3.6.1.2.1.25.4.2.1.4.27940 = STRING: "-bash" .1.3.6.1.2.1.25.4.2.1.4.28029 = STRING: "/usr/sbin/apache2"
.1.3.6.1.2.1.25.5.1.1.2.1 = INTEGER: 728 KBytes .1.3.6.1.2.1.25.5.1.1.2.2 = INTEGER: 0 KBytes .1.3.6.1.2.1.25.5.1.1.2.3 = INTEGER: 0 KBytes .1.3.6.1.2.1.25.5.1.1.2.40 = INTEGER: 12 KBytes .1.3.6.1.2.1.25.5.1.1.2.180 = INTEGER: 8 KBytes .1.3.6.1.2.1.25.5.1.1.2.233 = INTEGER: 356 KBytes .1.3.6.1.2.1.25.5.1.1.2.320 = INTEGER: 524 KBytes .1.3.6.1.2.1.25.5.1.1.2.354 = INTEGER: 4 KBytes .1.3.6.1.2.1.25.5.1.1.2.355 = INTEGER: 16 KBytes .1.3.6.1.2.1.25.5.1.1.2.402 = INTEGER: 864 KBytes .1.3.6.1.2.1.25.5.1.1.2.4187 = INTEGER: 492 KBytes .1.3.6.1.2.1.25.5.1.1.2.4420 = INTEGER: 200 KBytes .1.3.6.1.2.1.25.5.1.1.2.4602 = INTEGER: 180 KBytes .1.3.6.1.2.1.25.5.1.1.2.4604 = INTEGER: 144 KBytes .1.3.6.1.2.1.25.5.1.1.2.4699 = INTEGER: 3400 KBytes .1.3.6.1.2.1.25.5.1.1.2.7058 = INTEGER: 10788 KBytes .1.3.6.1.2.1.25.5.1.1.2.7487 = INTEGER: 20468 KBytes .1.3.6.1.2.1.25.5.1.1.2.10382 = INTEGER: 16872 KBytes .1.3.6.1.2.1.25.5.1.1.2.10397 = INTEGER: 19452 KBytes .1.3.6.1.2.1.25.5.1.1.2.12840 = INTEGER: 62356 KBytes .1.3.6.1.2.1.25.5.1.1.2.21398 = INTEGER: 3624 KBytes .1.3.6.1.2.1.25.5.1.1.2.21411 = INTEGER: 2096 KBytes .1.3.6.1.2.1.25.5.1.1.2.21813 = INTEGER: 12540 KBytes .1.3.6.1.2.1.25.5.1.1.2.21814 = INTEGER: 12528 KBytes .1.3.6.1.2.1.25.5.1.1.2.27021 = INTEGER: 3700 KBytes .1.3.6.1.2.1.25.5.1.1.2.27927 = INTEGER: 3672 KBytes .1.3.6.1.2.1.25.5.1.1.2.27940 = INTEGER: 2076 KBytes .1.3.6.1.2.1.25.5.1.1.2.28029 = INTEGER: 10096 KBytes
HOST-RESOURCES-MIB::hrSWRunPerfMem[index,HOST-RESOURCES-MIB::hrSWRunPath,/usr/sbin/apache2]
so..
