Bug ?
  • Alex_SYB
    • Feb 2012
    • 133
    Bug ?
    I do a check for a listen port and then a trigger on this item
    this is the mail i get when it gets triggered
    Trigger: SQL Server not listening on port 1433
    Trigger status: PROBLEM
    Trigger severity: Average
    Trigger URL:
    {TRIGGER.DESCRIPTION}
    Item values:
    1. SQL Listening on 1433 (xxx:net.tcp.listen[1433]): 1
    2. SQL Listening on 1433 (xxx:net.tcp.listen[1433]): 1
    3. *UNKNOWN* (*UNKNOWN*:*UNKNOWN*): *UNKNOWN*
    The graph show all 1's for this item
    This is my trigger
    {xxx:net.tcp.service[tcp,,1433].last(#1)}#1 & {xxx:net.tcp.service[tcp,,1433].last(#2)}#1
    so i check for the last and the one before ... not by time but by actual reads
    I am not sure why I am getting this ? Now the backups start around 6pm .. they might be introducing some lag.. but I don't think this is affected by that !
    When i look at last data its 1 and when i look at triggers for that server on that page there is nothing !
