hello,
I'm using Zabbix 2.0.2 server with a set of java (zabbix_java) and everything works fine. Needs to zabbix monitor more than 1 tomcat installed on the server. In options, the host is a possibility of writing another JMX port, but the default can be only 1 Is there any way to set this up? In the context of a single server can monitor several different ports JMX?
