Some kind of templates for similar triggers
  • DavidP
    • Sep 2012
    Hi all,
    When I want to monitor similar items for different hosts, I use templates.
    Now what can I use when I want to monitor similar, but not identical, items over a single/several host?
    For example for partitions management, I can define items such as:
    for /data: partitions.data.usage
    for /backup: partitions.backup.usage
    for /usr: partitions.usr.usage
    In our case, taking all our server configurations into consideration, we have around 25 partitions to monitor.
    In all cases, I want to set up the same kind of triggers:
    - warning when usage above 80%
    - critical when usage above 95%
    - plus some other tendency triggers
    Is there a way to define some kind of trigger template, so that I do not have to create, and maintain all those similar triggers for each unique partition?
    Thanks for your feedback,
    David
  • eskytthe
    • May 2011
    • 363
    Try to look at LLD in Zabbix ver. 2:
    http://www.zabbix.com/documentation/...evel_discovery
    Br
    Erik
