Action doesn't start
  • ortz
    • Jun 2012
    • 14
    Hi all,
    I'm having a big problem that I can't explain.
    For some reason some of my servers don't run the action even though the trigger is same as other servers.
    Nothing is disabled, configuration is the same...
    Action row from Configuration > Actions:
    Action expanded (Action):
    Action expanded (Conditions):
    Action expanded (Operations):
    Triggers that worked:
    Trigger that didn't work (see - in Action):
    As you can see from the actions, all that is not in maintenance, and trigger state problem and don't have the trigger name "No data received" should run the action... unfortunately that doesn't work...
    I'm tried many things and non worked... does anyone has any idea what to do next ?
    Few points:
    - All servers are enabled, same goes for items, triggers and actions.
    - The trigger does show as problem, only the action doesn't take place (I don't receive mail cause of this)
    Sorry for the un-linked links... I'm limited...
    Thanks!
  • mbsit
    • Sep 2012
    • 130
    I don't remember where I read this, but there are limitation that severity Information and Not classified are not send.
    Let's higher the severity to Warning and check again...
    Best,
    Grzegorz
    Pozdrawiam
    Grzegorz Grabowski
    ____
    Wdrożenia, szkolenia, umowy serwisowe
    Warszawa - Polska
    • ortz
      • Jun 2012
      • 14
      Best,
      Grzegorz
      www.mbs-it.pl
      hi and thank you for the quick response.
      that is not the case here... the triggers I showed are examples only... also average and critical are not starting the action...
      • mbsit
        • Sep 2012
        • 130
        Check if the user has RW permision to this host.
        Pozdrawiam
        Grzegorz Grabowski
        ____
        Warszawa - Polska
        • ortz
          • Jun 2012
          • 14
          Thank you!!!
          It was that, the user was not allowed to read from one host group, which made this problem...
          • mbsit
            • Sep 2012
            • 130
            So, I'm happy.
            Good description = fast solution.
            Bests,
            Grzegorz
            Wdrożenia, usługi IT - Warszawa
            Pozdrawiam
            Grzegorz Grabowski
            ____
            Warszawa - Polska
