item for checking zabbix connection
  • kopspa
    • Apr 2006
    • 19
    hi,
    how i can make an item that
    report the seconds from the last connection from zabbix_agentd to zabbix_server (active check)
    and then a trigger if seconds > 120
    many thanks!
  • erisan500
    • Aug 2005
    • 285
    Can you explain a bit more what you are trying to do?
    EriSan
    • kopspa
      • Apr 2006
      • 19
      i want to check if a remote zabbix_agentd is connected to my zabbix_server
      i use only active checks (because all my monitored machines are behind a firewall/nat) so i can't connect to the monitored zabbix_agentd port!
      i hope that you understand it now
      • just2blue4u
        • Apr 2006
        • 347
        Perhaps you can do this with item "agent.ping" ...
        (see http://www.zabbix.com/manual/v1.1/config_items.php for more information)
        Big ZABBIX is watching you!
        (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
        • kopspa
          • Apr 2006
          • 19
          can't be pinged... we have very strict policies for the firewalls
          i need to determine if a remote zabbix_agentd is connected to my zabbix_server (via a tcp check or any other trick)
          • erisan500
            • Aug 2005
            • 285
            Why don't you just use "status" and alert when status changed to 1?
            EriSan
            • kopspa
              • Apr 2006
              • 19
              doesn't return anything (tried as simple check, zabbix agent and zabbix agent active)
              it shows
              Status | - | - | - | Graph (in Overview -> Latest Data)
              i think that it must return 0 or 1, no?
              • erisan500
                • Aug 2005
                • 285
                What version are you using?
                Status used to work in beta9 but seems to be broken in beta10 :/
                EriSan
                • kopspa
                  • Apr 2006
                  • 19
                  server side beta9
                  client side beta9 and 10
                  but returns nothing on all hosts (b9 and b10)
                  • kopspa
                    • Apr 2006
                    • 19
                    otherwise can i make a check like this?
                    if zabbix_server doesn't receive data from a zabbix_agentd for 5 minutes (or if the time of the last check is more then 5 minutes), than launch the trigger (and then the action)
                    anyone can help me??? my setup is almost complete (basic checks, as if process slapd,mysqld, ecc are running ecc), but i don't know how to make the item and the trigger for this condition (i can't find something useful in the docs)!
                    • Alexei
                      Founder, CEO
                      • Sep 2004
                      • 5654
                      Function nodata(<sec>) will return 1 of no data were received for an item.
                      Alexei Vladishev
                      New York | Tokyo | Riga
                      My Twitter
                      • kopspa
                        • Apr 2006
                        • 19
                        ok but i see in the documentation that is only supported in 'zabbix trapper' items
                        what is a zabbix trapper? i can't find anything in the docs.
                        if i try to make a trapper item, i can't set the 'update interval'
                        • erisan500
                          • Aug 2005
                          • 285
                          You need to use that in a trigger like:
                          {Host.Win32:vfs.fs.size[c:,free].nodata(120)}=1
                          EriSan
                          • Alexei
                            Founder, CEO
                            • Sep 2004
                            • 5654
                            The documentation is wrong, sorry for this. It is supported for any item regardless of its type.
                            Alexei Vladishev
                            My Twitter
                            • kopspa
                              • Apr 2006
                              • 19
                              #15
                              now my setup is ok (and the boss is happy! )
                              thanks very much
