Two interfaces monitoring with Zabbix 2.0
  • Scarab
    • Oct 2006
    Could someone please help me:
    I have a couple of cisco routers, which has two pingable interfaces: external (for example, 10.0.2.1) and VPN (10.0.1.1). I want to monitor both of them.
    I've tried to create host and add two interfaces of "zabbix agent" type:
    10.0.1.1 test-gw-int
    10.0.2.1 test-gw-ext
    after i created two simple check items: "icmpping[{HOST.IP1}]" and "icmpping[{HOST.IP2}]", and two according triggers: "{HOST.DNS1} is unreachable" and "{HOST.DNS2} is unreachable".
    But no luck: if i put one of interfaces down, i got 0 on both items and two triggers are armed: "test-gw-int is unreachable" (that's correct), and "{HOST.DNS2} is unreachable" (suddenly, macros isn't resolved).
    Could someone please tell me:
    - How interfaces are counted in macros (HOST.IP1, HOST.IP2 etc)?
    - What does "default interface" means? This is not described in documentation.
    May be i'm doing something wrong? Could someone please correct me?
    b.r.,
    scarab
  • hupp
    • Feb 2008
    • 23
    I have the same problem, but just with webservers and ip based vhosts.
    I´m using zabbix_proxy to monitor the webservers, does this matter?
    Did you get any solution?
    • m_gularte
      • Jul 2012
      • 85
      Same problem here =/
      There are two forms to do that now (in my noob humble opinion):
      1 - Create itens like: icmpping[{$X1}], icmpping[{$X2}], icmpping[{$X3}] and set the macro values on the host. I´m using that and it's working so far...
      2 - Create itens like: icmpping[10.0.2.1], icmpping[10.0.2.2], icmpping[10.0.2.3]. It works too, but i'd rather the first option.
      Anyway, sorry for my poor english.
      • hupp
        • Feb 2008
        • 23
        Because it goes about many webservers i will use option 1. Also the item checks are in a template and i can use the macros there.
