which USB GSM MODEM to use ?
  • verus
    • Feb 2009
    • 67
    I would like to send sms messages with a USB GSM modem.
    I assume it is possible ?
    Does anybody has experience with installing a USB GSM modem in Linux/zabbix ?
    If so, can you help me choosing which one is known by linux and easy to install and use ?
    thanks,
    Verus.
  • HullZabbix
    • Feb 2011
    • 104
    I'm not sure which you should go for, but I would avoid any Huawei modems
    A lot of them (including mine) suffer from a bug with zabbix which sends out tripple sms's. We need to use external scripts (very easy to setup!), but it's still a hassle.
    • killed
      • Sep 2012
      • 14
      Research and search usb_modeswitch, you may 'play' with any USB3G you have
      Install usb_modeswitch by yum or compile from source
      But absolutely, if USB3G supported by default system is better
