Log files monitoring
  • pradhanparas
    • Jul 2012
    • 45
    I need to monitor log files (such as : /var/log/message). I followed this link
    http://www.zabbix.com/documentation/...ypes/log_items
    But it does not say how to create trigger?
    Anywhere I can refer which is more clearer?
    Paras.
  • Colttt
    • Mar 2009
    • 878
    an example:
    {SERVER:log[/var/log/syslog,zabbixtest].count(180)}>2
    if zabbix found "zabbixtest" 3times in the last 180seconds = alarm
    Debian-User
    Sorry for my bad english
    • pradhanparas
      • Jul 2012
      • 45
      Thanks for the reply. I am not seeing anything by doing that. This is what I have done so far
      Create Item:
      Host: myhostname
      Type: Zabbix agent (active)
      Key: log[var/log/messages,error]
      Next values are left default
      Create Trigger:
      Name: Log Item Trigger
      Expression: {myhostname:log[/var/log/messages,error].count(180)}>0
      Now how to test?
      I did : echo "error" >> /var/log/messages.
      What did I miss?
      Thanks in Avd
      Paras.
      • pradhanparas
        • Jul 2012
        • 45
        So far this working now. I got the wrong Serveractive ip. So this has been fixed.
        One more question:
        What is the good practise to monitor the log files? Look for Error, Warning, CPU, pam_ldap?. Can we do like this?
        log[/var/log/messages, error , warning, Error, WARNING] in single key?
        Thanks!
        Paras.
        • nicolasg
          • Apr 2011
          • 50
          Can you be more specific ? I have the same problem trying to monitoring a log file for a specific keyword..
          • pradhanparas
            • Jul 2012
            • 45
            I had client's IP in Serveractive instead of Server's ip where zabbix_server is running.
            Paras.
            • jerrylenk
              • May 2010
              • 62
              Hi there, Paras and Nicolas,
              That is not how it's done. Only the second argument to the log[] key is taken as pattern to filter the log.
              Edit: It does not behave like I would expect with regexp, but I am trying this right now....
              If you absolutely want to use the count() function for a trigger, please look at this thread for a caveat, but rather try nodata().
              Good luck! Jerry
              Last edited by jerrylenk; 19-10-2012, 18:51. Reason: the part about regex doesn't apply
              • jerrylenk
                • May 2010
                • 62
                OK...
                Seems not so complicated after all:
                [Ff]ehl finds words like 'Fehler', 'fehler', 'fehlgeschlagen', ...
                (I'm german; that's how we spell failure)
                ERR|err finds 'err', 'error', 'ERROR', 'verraten', but not 'erRor'.
                Hope this helps.
