Im trying to find the right monitoring solution for my company and im hoping Zabbix is it.
We need to be able to connect over (cisco & open) vpn to 5-20 remote sites (each then containing about 10 centos machines) and run custom scripts or commands which check the status of our application on the customers site. If possible i dont want to install anything on the customers machines so the proxy option looks ideal.
Can Zabbix be easily used to do this. Do you configure the VPN in the main zabbix server make the vpn connection to zabbix proxies and pull back the monitoring results for a site for processing and alerting if necessary? Or do you configure the vpn outside of Zabbix and line up the times for it to connect when you configured the vpn to be open?
I have looked at nagios and didnt feel it could do what i wanted.
Any help would be appreciated!
